I am trying to source a 3" Stainless Steel Dump + Front Pipe in one, but I am having trouble finding one.
I was wanting to find one, online or otherwise, buy it and install it myself, but am having no luck.
Is it possible to find one for less than $400?
Also
Is there any benefit from having seperate dump and front pipes, apart from it being a little easier if you wish to change your turbo?
Thanks
Adam
https://www.sau.com.au/forums/topic/14706-3-stainless-dumpfront-pipes/
  • Replies 48
Well, I was about to say have a look at a thread in the FS section....but it's gone !!. To cut a long story short, a member (BATMBL) was offering dump/front pipe combos in SS for around $350 or so (as I said, threads gone so not totally sure). Unless the mods have deleted it for some reason (maybe, dunno) then can only assume he did that himself. If that's the case probably means he can't get them anymore......which will be a shame if true, cos I was after one myself :)
I've PM'd him so hopefully will find out what's going on....if that deals gone tho, JMS have SS dump pipes for $350:
http://www.japanesemotorsport.com.au/partsinstock.htm
or combined dump front pipes for $325:
http://www.japanesemotorsport.com.au/partsinstock4.htm
[doesn't say whether they're SS tho...probably not].
I was really after the cat too
wouldn't cost that much its only a small pipe! when i had my last car (ma70 supra) i went to an exhaust shop and the guy made up a 2.5 inch exhaust for $300 which included a muffler and bolted onto the cat.
i would expect a muffler shop / exhaust shop to make one custom for $100-150
Originally posted by turbomad
Hello go to www.flyn.com.au they have them there for $280, they also have cat's, exhausts and other high performance stuff.
Yeh, but that price is for mild steel and they want $500 for the SS version.....BATMBL's price was only around $350 for the SS version
Why pay extra for stainless? I had a mild steel exhaust on my VL turbo for 8 years and it was fine, who really keeps a car long enough that it would outlast an exhaust system and need replacing to warrant the higher cost of stainless?
Also check EBAY as Flying Performance sell there too, I got mine for $235.
Why ??....horses for courses AFAIC, SS is more likely to last esp behind a turbo - you can't just generalise and say that MS is the best way for everyone as every situation will be different. It worked for you and that's good, but since the cost diff for the SS over MS that BATMBL was offering was only about $70 (compared to $150 for the same things from F/Perf), I'd pay the diff to get SS every time.
I think you'll find the properties of SS are such that in situations of great temperature range, such as when bolted on the back of turbo's it has a tendency to become slightly more brittle than mild steel.
Not to say it WILL crack. Most likley it wont. Alot of turbo rotary owners I know over here swear by mild steel on turbo dumps and so forth simply because they have constant cracking issues due to the amazing amount of heat that rote's put out.
Anyway this is bound to start a shit fight, go with what your happy with. Im happy to use mild steel as are alot of people.
Red17
Ahhh...no....not true....and I'm speaking professionally, as a metallurgist:)
so what is the advantage of stainless, apart from being stain-less and better looking? Do they withstand higher temps? Are they lighter in weight? I have heard they last longer but that is about all you hear from an exhaust shop...
Just wanting to decide which is the better option before i buy too. I have heard that a lot of skylines in Japan just have mild steel aftermarket exhausts - but it may be just the cat-back section though, cant remember.
Stainless has superior high temp corrosion resistance to mild steel - no question. As to why people have had trouble with it, all I can say is that it is rare to find that the material itself is at fault.....other factors such as poor design or poor welding are more likely causes. But, without an understanding of the cause, to blame the material is wrong.
MS is used because it is cheap, readily available and easy to work with. In this case, the cost diff between MS and SS is sufficiently small that I'm prepared to pay it for the extra benefit of having SS. Had the diff been greater the decision would not have been so simple.
I think I'll leave it there, I also don't want to get into a sf over this and people can make up there own mind.
Thanks SteveL: I think I will go SS too, in the case of BATMBL's offerings its only $100 difference and long-term I think it represents an insignificant outlay.
Skippy: now you have just swung the argument back the other way, who are you agreeing with?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
