hey guys this is my new 34.. big jump from the 33.. as this is the 2000 model with only 18,000ks on it .. so far modded full xforce turbo back item , jic hyper D coilovers , 20" koya inox , genuine nismo led lights
thinking of a good combo to suit the car otherwise might use my old plates 53XYN
https://www.sau.com.au/forums/topic/147075-my-new-34/
  • Replies 50
Posted Images
hey fellers thanks for your comments , agrred the 34s are more refined then my S2 33 i had b4, yes its a S2 2000 model , silver badges bud nothing gold there... rides exactly same as when i bought the car with stock setup and 18"s on themnext cruise im there i hope theres more yellow ones out there tho
https://www.sau.com.au/forums/topic/147075-my-new-34/#findComment-2745337
hey guys , yes jo got me those wheels, kevin for the jics and rest of the suspension parts , don for the guard rolling , paid 2950 full set for wheels 2200 for full suspension work , no scrubs whatsoever not even a tiny bit, fides flat loving the 34 over my 33 !..
Choyda , thank god for 34's cant believe how much of improvement these are over my last car !.. although one blue and white my yellow will stand out !
Edited by 53XYN
https://www.sau.com.au/forums/topic/147075-my-new-34/#findComment-2746057
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
