*prices Reduced* Car Audio Gear - Pioneer, Boston, Rockford Etc.
After having to sell my pride and joy earlier this year (r33 S2), I've only just come to terms with the fact that I also have to sell my audio gear that I ripped out. ;)
These items were installed early 2003 and were taken out in May this year. They haven't seen a great deal of use, as the car was really only driven for short trips.
For sale are:
* Pioneer DEH-P8450MP deck - $350* **SOLD**
* Boston Rally RC620 6.5" splits - $175* **SOLD**
* Rockford Fosgate Punch 200S amp - $150*
* Rockford Fosgate Punch HE RFP3412 12" sub + box - $150*
* Clarion V-Net 450 4 channel amp - $130* **SOLD**
* JVC CH-X1000 12 disc changer (actually from my Fiance's Liberty) - $100 **SOLD**
Would make an excellent starter pack. Originally worth well over $3000
*Special package deal - $800* for the lot!
For more info and pics, please visit the following (dodgy looking) page:
http://www.pnc.com.au/~nathan/caraudio
Pickup from Sydney would be preferred, but other options could be discussed for the serious buyer.
Email: [email protected] (preferred contact)
Mobile: 0404 011 857
No low-balling please!!!
Edited by Knat
Hey mate,
I don't actually have the gear with me (at the Olds' place). I'll try and get there ASAP to check model numbers etc.
I know what you mean about there not being much on Google. I assure you it does exist though! :)
Clarion amp was sold tonight in an on-the-spot deal - Sorry Foznice.
Deck and stacker are being held.
Still have the Boston splits, Rockford amp and Rockford sub.
umm...the RF amp...wat is the RMS rating bridged?
Rockford Fosgate Punch 200S:
* Channels - 2
* Per channel power - 50 W X 2 @ 4 Ohms RMS,100 W X 2 @ 2 Ohms RMS, 200 W X 1 @ 4 Ohms Bridged RMS
* Total power :400 Watts
* Bridgeable - Yes
Actually still have the test certificate from RF that rates it at 264 W RMS
Would prefer to sell it with the RF sub too.
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
