here is what i have for sale out of a wreck r33 gtst with 76,000km
2 x 8 spoke 16" DRIFT wheels with crappy rubber mulitfit ...........
1 x Diff complete
1 x rear calipers and discs
1 x HICAS 4ws unit
1 x Left Hand Rear Tail Light
1 x rear bar
2 x rear rio
1 x series 1 back seat
1 x complete set of complianced seat belts
2 x rear side panels Left & Right
2 x kick panels
1 x complete carpet
1 x hand brake lever unit
2 x rear wipers including motor
1 x pair of sunvisors
2 x roof center lights
2 x roof lights that sit in between sunvisors section
1 x rear cradel
1 x steering rack
1 x K Frame
1 x Steering Coloumn
1 x rear vision mirror
1 x boot lid with brackets and gas struts small dint
1 x fuel lid
1 x skyline rear garnish
1 x pair rear stock shocks and springs
1 x clock spring for airbag models
1 x ignition barrel with key
1 x indicator/wiper stalk
1 x gtst clutch/brake/accelrator pedal box complete
1 x gtst cluch cyclinder
1 x gtst brake cyclinder
1 x gtst fuel pump
1 x accelrator cable
alot more will add as things go....... ALL OF THESE ITEMS ARE GOING CHEAP SO YOU GIVE ME THE AMOUNT U WANT TO PAY AND IT WILL BE YOURS WITH ALITTLE NEGO!!!! GRAB SOME CHEAP STUFF GOTTA GO CLEARING UP ALL THE UN NEEDED STUFF.......
Edited by SXC_R33
https://www.sau.com.au/forums/topic/147094-r33-gtst-parts-4-sale/
hey, do you have the driver side door control unit, for the windows and locking as well.. i need the hole unit, the control part and the computer box that attatch to it.. should look like this but with the computer cliped to the bottom..
series 1 and series 2 should be the same with this part right/? thanx
Edited by seriesII
sorri i dont have the black plastic surround u guys require
The carpet is black in colour
in regards to the ashtray i might have i will pm u if i can find it!! cheers
guys offers offers offers its gotta go.......need to clean up
hi how much wold u be settling for just the frame of the gearbox e.g the leather and the plastic covering? and also the handbrake leather?
and do u have any badges left i would realli like a skyline S badge
complete diff disc to disc gimme an offer and its urs i dont know what these things are worth
intercooler pipping i have got stock 1..... i am in keilor
ZAS i dont have what ur after sorri
call me if u want 0402090079
Edited by SXC_R33
Actually there are 3 differant types and one wont work with another :)
Closed.
When are people going to read the rules?
Prices must be listed for all parts being sold!
Moderators are tired of having to continually ask people that completely ignore the rules of the classifieds.
Guest
