hey guys
my car sounds as if your riding on a train
it sounds as if at first doing 20km its grinding something in the back then tends to follow up with a train sound coming from the diff or back of the car?????
its a r33 gtst, series 1
anybody got an idea wtf it is???
https://www.sau.com.au/forums/topic/147095-train-sound/
brakes maybe ... Is your handbrake adjusted correctly ?
Have you changed anything ? ie wheels etc
nopes but brakes do need bleeding, maybe a net set also?
hand brake adjusted nup onli thing i know of is a full lockup on a strait cause of a taxi driver....?
what do u reckon i shud ask my mechanic or myself check on ?
https://www.sau.com.au/forums/topic/147095-train-sound/#findComment-2745559
mate start by checkin the torque of the rear driveshaft nut in rear hub assembly and check rear wheel bearings for noise. to check wheel bearing jack up rear of car and feel springs and u spin the tyres if u feel vibration there is something not right there. could also be some back lash in the diff but i would be more inclined to say your problem is either a wheel bearing or a wheel bearing/loose driveshaft nut. good luck
https://www.sau.com.au/forums/topic/147095-train-sound/#findComment-2771763
