well i got bored today and thought i would remove my dual battery setup in the surf, replace with a damn expensive single battery and get rid of the factory air intake (which was on passenger side of engine bay) and chucked in a k&n pod on the drivers side where the 2nd battery used to be.
This leaves plenty of room for my top mount r33 intercooler now :P
https://www.sau.com.au/forums/topic/1471-my-new-pod-filter/
well i just went down to the chinese takeaway and got half the town looking.. with the loud psshhh! as i pull in :P sweet
took heaps of planning and then 1hour max. I had pulled everything apart so many times i knew exactly what to do.
The induction noise is a pain in the arse, but i got K&n as at just over $100 i thought it would have to be better than the $40 ****ty ones.
the main time was trying to get the damn pipe onto the turbo as the aircon sits right in front. let me just say i hope i never have to take it off!!
https://www.sau.com.au/forums/topic/1471-my-new-pod-filter/#findComment-28936
Birty
Probably because they make the best filters in the world.....! Every single filter test I have read has the k&n in front and the trust one last:lol:
A couple of year ago I was at the Coffee Club at Broardbeach and a guy in a Ferrari 355 pulled up with Japanese plates and everything......He told me a big story about how he was one of the owners of HKS (Not sure but a good story) after I raced him in my starlet.....anyway he had all this cool HKS gear on the 355 but a pair of K&N filters. He said why the K&N filters? He said that "His guys" had tested them all and found them to be best.
Who was I to argue with the man with the 355.
Just thought I'd share that with you all
https://www.sau.com.au/forums/topic/1471-my-new-pod-filter/#findComment-29267
We had a HKS one on Sinbad when we got it. When we went exploring in the engine and found out that the filter was crumbling we decided to take it off.
The HKS one was ****en loud... about 5 times louder than the K&N one we got to replace it.
I love the intake noise.. Now that I know its only around $50 to get the HKS pod filter I might change it back. But we will see what happens...
https://www.sau.com.au/forums/topic/1471-my-new-pod-filter/#findComment-29278
Guest INASNT
Originally posted by BOOSTMEISTER
Birty
so did u beat him in the starlet?
https://www.sau.com.au/forums/topic/1471-my-new-pod-filter/#findComment-29940
Originally posted by Squizz
Now just up the boost and a front mount!
already done the boost. just using a turbosmart boost controller now running 13psi up from around a standard 8psi. The cooler is a top mount as the 4wd has 2 radiators at the front and no room for a front mount.. also saves heaps of piping by having a topmount.
https://www.sau.com.au/forums/topic/1471-my-new-pod-filter/#findComment-30316
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
