  • Replies 49
thanks to everyone who replied, i took your advice and it worked now i am back on the road and finally getting to use my new 17's to go with the r32 brakes. the problem was that i had the callipers on the wrong side i.e. the nipple was at the bottom and like u guys said it would look like its bleeding good but there was still some air trapped at the top of the calliper. so lastnight i switched them and bled the lines again and she works good. there is some soft feeling and like u said its because i am using the stock master cylinder, so the hunt is on for the r32 master cylinder and booster.
thanks again for all the help
Can we summ this all up and sticky ? )) The lines, the brakes etc ?
i'll add some into that parts list sticky when i get around to it...
EDIT: BTW while on the topic of master's and boosters, i called up holford motors here in melbourne, they quoted 150 for both a booster and master off a R32 gtst. That sounds reasonable for 2nd hand yeah? Still haven't upgraded mine since i put the r32 calipers on over a year ago...
Edited by skypy12
i didnt upgrade my booster, simply the master - its a direct fit :P
How much difference did it make when you upgraded just the master cylinder, is it worth just doing that because i have noticed that the booster on the R32's is physically larger.
Oh and ill have to send jinman a PM, around $120 is very cheap for two ADR approved lines.
so summing up wen upgrading brakes on a a31.... u need 2 change the brake master cylinder? for sum weird reason.....
not true.... stock can be used... his was just bad...
i use the stock (s13 same) the only difference is about 2inches of extra travel. actually puts it at the right heighth to heel-toe, or clutch kick in a brake-drift. but for SOLID pedal feel upgrade the MC....
Edited by 4DoorWhore
Well actually you are wrong there. Well technically if you are sooo broke and cant afford an upgrade then yeah you can use the standard master cylinder.
But really the whole point of doing a brake upgrade is to get better braking. The calipers will only be as good as the master cylinder, and if the master cylinder isnt displacing the proper amount of fluid you get shitty brakes. Upgrading gives you that SOLID pedal feel, which is what brakes are meant to feel like.
yes partly true, but by upgrading to the Z32 Master cylinder your only increasing the flow rate due to the larger diameter of the cylinder its self. the compensation for this in the S13 Master which has a lower flow rate is the time of flow through the cylinder is increased. there for a longer time till the brakes are activated fully, longer pedal travel also. but due to the fact that the GTR brakes have the same diameter brake lines and just require more pedal travel, when bled properly the S13 MC will lock the brakes just the same with a slight delay that is... now if you want to get serious and you want equal pressure you need a brake proportioning valve...
Its true, Im not referring to any particular master cylinder im saying generally. Brakes are measured in force not flow rate because its a closed circuit. Im just saying as an example.... When you see those fancy brembos like 6 or 8 pot now arent they? I can guarantee you will not see a piss weak master cylinder. The fact of the matter is that a bigger piston at the master cylinder will increase the force at the caliper pistons. Because you are displacing the fluid via a larger area of the piston face, which is more pressure. If you are using a small piston face to put pressure onto the same calipers not as much force will be on the caliper pistons resulting in shitty braking performance.
Anyway. Id say most vehicles with front and rear discs would have proportioning valves. Then again so would the newer vehicles with drum rear i think. A proportioning valve is to disperse the force of pressure between the fronts and rears, and generally its split 60/40 i beleive, 60 going to the front and 40 to the rear. Its not meant for equal pressure all round.
Just my 2 cents :)
gtrchick i think what you are saying makes sense, here is what i would do, i currently have on the stock master cylinder with the 4 piston brakes, i would look for the bigger master cylinder and put it on and see if it make any difference in performance or if it just reduces the peddle travel before the brake are 100% activated. I would try to do this mod soon and let you guys and girls know, i cant say when as i have to look for a master cylinder thats in good condition, give me a 2 week to try and source one.
  • 5 weeks later...
read up.... i just told you there is a difference in pedal travel... and as GTRchick says it takes more force (my mistake) though people with bad braking habits may benefit from this a little since its somewhat forgiving.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
