For Sale
Nissan R32 Godzilla GTR V Spec II
White, fully re-built engine, highly modified car, thousands spent have all receipts, serious buyers only. Personalised plates, rego, perfect condition, very regretful sale.
$30, 000 Serious buyers only
ph: 0438 881 462 or PM me
I live in Brisbane
As to the list of mods, here are most of them:
Trust front mount
Twin 3 inch exhaust
HPC coated dump pipes
HKS 2530 turbos
Toyo T1R 235/40/17 brand new
G7 Panasport Rims
272 HKS cams
HKS cam gears
Ogura twin plate clutch
Sard 720 cc injectors
In tank fuel pump
Air water bypass/bleeder
Remote oil cooler and filter and speed flow fittings
Custom blow buy, speed flow fittings
Forged pistons
Brand new crank (R33)
N1 Balancer
N1 Water Pump and Oil Pump
O-ring block
reconditioned tail shaft
ARE radiator
Silicon radiator hoses (Blue)
Gates timing belt
Link ECU
Brand new head, valves etc
Alarm, auto windows up
AVCR
Autometer fuel pressure and boost gauges, on the piller
NGK iridium spark plugs
Runs Motul 800v oil
no air flow meters, runs a map sensor
Koni adjustable suspension
White leather inserts
Isotta steering wheel
Isotta windsceen wipers
Tinted windows
Big stereo, cadence Z4000 amp to run the splits, VDO HPC 1700 6.5inch splits
6 x 9s in the back
US audio bone crusher 1200w Amp to run the subs 2x 12inch
Battery in the boot
Edited by MYR32GTR
https://www.sau.com.au/forums/topic/147104-r32-gtr-v-spec-ii/
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
    • More photos are up, and the price has been dropped to $16,000. It's just had a service and a new 12V battery, too.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
