jasevr4 Posted January 3, 2007 Share Posted January 3, 2007 The car is a WGC34 RWD not 4WD Out of curiosity, how can you tell the difference? Aside from it being RWD - is there any way to tell if it's a RWD converted RS4? Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2791333 Share on other sites More sharing options...
darrinspencer Posted January 3, 2007 Share Posted January 3, 2007 Out of curiosity, how can you tell the difference?Aside from it being RWD - is there any way to tell if it's a RWD converted RS4? Apart from the artical saying it is a WGC34, have a look at the strut towers in the engine bay Rwd Stagea have totally different strut towers to a 4WD RS4 Rwd front suspension does not have the upper wish bone arm and use a different front strut/shock. Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2791346 Share on other sites More sharing options...
Kushil Abeysinghe Posted January 3, 2007 Share Posted January 3, 2007 thanks for great pics......love that white one......... Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2791477 Share on other sites More sharing options...
Stinky Rooster Posted January 3, 2007 Share Posted January 3, 2007 Apart from the artical saying it is a WGC34, have a look at the strut towers in the engine bayRwd Stagea have totally different strut towers to a 4WD RS4 Rwd front suspension does not have the upper wish bone arm and use a different front strut/shock. Does that explain the shots of the modded strut towers? I was wondering what that had to do with the rest of it. I mean, the turbo that was capable of swallowing a small child was pretty self explanatory, but I couldn't figure out what the re-welded strut tops were trying to show. Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2791579 Share on other sites More sharing options...
funkymonkey Posted January 3, 2007 Author Share Posted January 3, 2007 The car is a WGC34 RWD not 4WD hmm you're right it is a WGC34... lol can't believe I didn't see the big word in the middle of the page. Whoops. Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2791675 Share on other sites More sharing options...
Ska Posted January 3, 2007 Share Posted January 3, 2007 Wow, what a freakin animal Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2791997 Share on other sites More sharing options...
MADGT4 Posted January 3, 2007 Share Posted January 3, 2007 but I couldn't figure out what the re-welded strut tops were trying to show. Spot Welds for Chassis regidity im assuming Something you see on most drift car out of Japan On another note this thing is so damn hot! Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2792011 Share on other sites More sharing options...
jasevr4 Posted January 3, 2007 Share Posted January 3, 2007 Apart from the artical saying it is a WGC34, have a look at the strut towers in the engine bayRwd Stagea have totally different strut towers to a 4WD RS4 Rwd front suspension does not have the upper wish bone arm and use a different front strut/shock. Thanks Darrin - is there any benefit to running this at all? Or is it simply just the way that you run different setups? 4WD - you want the upper wishbone arm, RWD, you dont? Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2792033 Share on other sites More sharing options...
darrinspencer Posted January 3, 2007 Share Posted January 3, 2007 Thanks Darrin - is there any benefit to running this at all? Or is it simply just the way that you run different setups? 4WD - you want the upper wishbone arm, RWD, you dont? I can't answer what the benefits are, but the 2 are not interchangeable. The RWD Stagea comes from the factory with a totally different chasis/strut tower and supsension mounting points in the front to the 4WD version, so the suspension will not be interchangable If your car is a 4wd version, have a look at your strut towers and compare them to these rwd version towers. You should be able to spot the differences in size. Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2792054 Share on other sites More sharing options...
jasevr4 Posted January 4, 2007 Share Posted January 4, 2007 Thanks Darrin. You can really see the difference here: Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2792432 Share on other sites More sharing options...
GoldZilla Posted January 4, 2007 Share Posted January 4, 2007 Thank fck I've got broadband. Nice shots Shan, and no shortage of them either! Good work! RWD strut towers gives you a bit more room in the engine bay for adding accessories, I've got no idea where I'd be able to mount a remote oil filter mount or catch can... Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2793354 Share on other sites More sharing options...
captinsane Posted January 5, 2007 Share Posted January 5, 2007 It looks like that car has had just a few changes to it... RB25 to a RB25 NEO...several Intercoolers etc... I can't read japanese but i assume it would be revealed in the article Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2795744 Share on other sites More sharing options...
jasevr4 Posted January 5, 2007 Share Posted January 5, 2007 it's a S2 though isn't it? wouldn't the neo have come with it? Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2795854 Share on other sites More sharing options...
captinsane Posted January 5, 2007 Share Posted January 5, 2007 It looks like that car has had just a few changes to it... RB25 to a RB25 NEO...several Intercoolers etc... I can't read japanese but i assume it would be revealed in the article my bad?....stupid mistake...they just brought the plastic crap cover off... stoopid chris...stoopid chris Link to comment https://www.sau.com.au/forums/topic/147105-cover-car-of-drift-heaven-mag-dec-issue/page/2/#findComment-2796847 Share on other sites More sharing options...
