Hi All,
Just wondering if anyone had time to give me a sneak preview of what my car would look like with different coloured rims.
I'm looking for images in bronze, gold, gunmetal grey and black.
If anyone can help me out, I'd really appreciate it.
Thanks in advance.
https://www.sau.com.au/forums/topic/147125-pls-change-rim-color/
  • 3 weeks later...
