Don't listen to them arggggh!!
Got 90,xxx+ km's on it? Rebuild it. Simple.
If i see another person spend 10 grand+ on bolt ons im gonna scream. It's just dumb...ull high flow ur turbo, run higher boost, throw an fmic on it, with a decent new exhaust, new ECU and then after u run 20psi thru stock internals u'll wonder why 10,xxx km's later why your bottom end is f**ked.
Be smart. Make yourself a decent building block. Forge ur bottom end, make it strong.
$4k on forged rebuild with new metal head gasket, replace everyting. New bearings, machine ur cranks etc etc.
$900 on PFC (if u can find one)
$700 on a decent FMIC kit. Dont but hybrid generic shit.
$900-$1500 on a decent exhaust.
Once you have done this u can buy a much bigger turbo and gaining power will be easy.
Bolt on, and ull regret it =)
  • Replies 70
Posted Images
Have a read of this, it'll get you started.
http://www.skylinesaustralia.com/forums/in...showtopic=45218
Remember
Turbo + dump - 2300
ECU/tuned - 1800
Tyres - 1500
Diff - 1000
Suspension - around 1500?
I/C - 600
Clutch - 1000
Labour for it all - 2000-2500
Your off and running @ $12,000... so the building of a motor (another 7k) is out of the question.
In the above there is also stuff that i probably have not included so costs could be higher yet
If your being slugged 7k to build a motor ur taking it to the wrong place.
ok, i have the exhaust and intake covered.
* Get front mount
* Boost control and boost increase
* ECU
* New turbo ( GT30R or GT35R maybe)
* up-grade fuel pump
* Up-grade AFM
* Metal Head gasket
* Maybe cam/cam gears
Motor in/out - 1000
Pistons - 1400
Rods - 400 (GTR)
Crank/or machined crank with collar - 800
Upto 3600 before the block is even touched, head gaskets, bearings, new oil pump, etc etc. Mates rates are not counted here im afraid
Either way. IMO, totally not worth building the motor if there is nothing wrong with it.
So many people have made 250rwkw on stock motors and most are still alive.
Tuning is the key to longevity.
Drop the comp via a headgasket and providing the tune is safe there is no reason for it to pop.
If the motor simply gets tired and has a lot of blowby then yes its lived a good life. If it breaks a piston, look at the tuner or yourself for doing something silly with it. Its as simple as that. Its not a perfect world so its up to yourself to ensure the tune is suitable for the conditions. Have it run up on the dyno on a hot and icy cold day.
Without labour (motor in and out) mine essentially cost 3.8k just for the bottom end bits inc. gaskets, forged pistons & std rods.
Rebuild the head, thats another 500 + VRS kit $280 + labour of the motor in and out and it will be up close to 6k if not slightly over by the time you throw fluids in to the motor/gearbox etc.
And thats not including the added expense of GTR Rods and crank collar.
R31Nismoid.. 7k is on the conservative side. :O
Yeh exactly.
It also depends on what he wants to do with the engine. He may not have to change his cranks. Plus labour varies from state to state and region to region dependant on who you use. So for what i got for 4k, in most places would cost 5-6k.
But im a big fan of rebuilding 25s when they near 100,xxx....If u want decent power, make the whole engine fresh, not just the head.
But your right Nismoid, if it aint broke, why fix it? But id still be ripping off the head and looking for those signs that lead towards a future rebuild :O
Edited by Sambo33gtst
i will also be doing this to my R33 in the future and by then im hoping to have most of the bolt ons done so the 10K will go straight to a rebuild or even a RB26 conversion for something diffrent (would have less ks as well)
Some times its good to do the bolt on stuff while you have the cash to throw around.. Then when the motor needs to be rebuilt you are 'forced' to do it..
Well it works well when there's a better half in your life that complains about how much money is spent on the car. :)
Its easier to justify that house redraw or loan to 'fix' a broken motor than it is to buy bolt on parts. :O
How i would spend 10k:
Dont sell the car, Keep the car, rb25det's have lots of potential, and r33's are a great car!
3"dump/front pipe
Highflow cat
Some type of japanese cat back, hks,trust etc
Fmic, its up to you what type you use
Standard airbox with K&N filter, or a decent pod (apexi/hks etc) in a decent cold airbox with good ducting
GCG Highflowed standard turbo
Apexi Power FC
Greddy Profec B Spec 2
Nismo 550cc injectors
Nismo fuel pump/Bosch/gtr etc etc
Upgraded clutch
Get it tuned by someone that is well known and recomended by skyline owners
Some 17" or 18" wheels with 235 or 255 tyres on the back and some decent suspension, upgrade the brake pads.
I didnt quote N.Z prices as aussie prices as obviously going to be different.
Edited by nizmo_freek
Goto nengun, look dream make list and buy!!!
thats the way to do it, oh and to kill the moment of high power to non rebuilt motor, 244 rwkws at 11psi with gt3037proS and spat the little end bearing Oh 130000 km on the clock??
Little advice, do the basics exhaust(done), fmic, suspension, fuel pump, injectors, pfc, pod filter :rofl: , coilpacks, cams, and then tune.
By that time you'll have money left over Get use to the power then do the next stage after you save more money, IE: turbo. and just in case always always save and plan for anything that is unexpected that might happen. Saves the heart ache in the end.
Theres no real way or set way you should follow to do upgrades, but then again, why not have a read of others experiences on here then do a list.
The other advice, unless you know its genuine km's for sure, never take notice of the KMS on the dash
My opinion
Cheers A
Edited by Devils_Advocate21
Motor in/out - 1000
Pistons - 1400
Rods - 400 (GTR)
Geez you are getting ripped off.....
pistons 1100....max
gtr rods 100-150....
motor in out 800 max....
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
