3 points, $169
EDIT: should clear this up...
its only 3 poits for a major defect, which is maily what they give now as to eliminate imports off Victorian roads. If you get a minor one, then they usually dont fine you or lose any points but as stated its really up to the officer as to how severe the fine is.
Edited by ctjet
Not always - sometimes you can get a minor notice with no fine nor points loss... but you still need to fix the issue and present the car to VicRoads.
Not 100% on the law - but I believe this is mostly at the discretion of the officer.
Dave got a fine with his last (major) defect... i tried digging up the paperwork to see if the fine was as a result of the defect, or if it was in relation to a particular illegal modification, but I can't find it anywhere. :rofl:
I told him to fight it because he was booked by an officer on a motorbike, who removed his helmet while he gave the car a going over.... i was under the impression that once they removed their helmet, they were considered to be "out of uniform", but he decided it was easier to just shut up and pay up. ;)
LOL thats pretty funny. I'm 200% certain that they are still able to give out fines and perform their officer duties without their helmet on. Had that gone to court i'm sure the officer and judge would've been laughing for a long tome.
I've never lost points for a defect but I have got the $169 fine about 3 times while getting defected, the fine was for driving an "Unsafe Vehicle". They can take 3 points for this I think but its up to the officers descretion to take the points or not.
I've also had major defects where i didn't get fined.
The law may have changed though recently.
Well... motorbike Police might be able to, but regular Police are improperly dressed without their hats
I just thought it might transfer across :rofl:
thx guys
so its pritty much up to the officer and if he wants to be a prick or not
wats considered a minor defect offence? like couple mods? IE cooler and boost controller? or are all mods no matter how many considered a mojor defect?
Major defect is when they get you for 3 or more things.
If you want to find out what's defectable, go check out the legal info links in the sticky thread up the top of this section.
Provided the officer identifies himself then he can quesiton you , book you etc even if he is off duty and wearing his underwear on his head. :rofl:
if that's the case, why would there be such a term as "off duty"?
Wouldn't that mean that they are "on duty" 24/7?
How would they be able to "book you"?
In order to do that, they would have to have access to the proper paperwork.
I understand that they may be considered a more viable witness in certain situations, but when it comes to an off duty Police officer, don't you and I have exactly the same amount of power that they do?
On TV, off duty policemen can kill hundreds of people - say they are all bad, and get off scott-free (and usually hook up with some strumpet ex-hooker with a heart of gold).
Troy wears his underpants on his head quite regularly, so I'd be inclined to believe him. Note the part about identifying themselves as an officer (and no doubt flashing the 'ol warrant badge around)? - I'm sure he'd be able to stay off duty, dropping pints and betting on the dish lickers if he kept his yam shut.
That said - I received a yellow sticker in the R. No fine, no loss of points. Just told to get my trumped up charge of the placcard not matching the load weighting on my tyres - fixed.
I just thought it might transfer across ;)
I actually defeated a "failure to obey an officer" or whatever.
because he wasnt in uniform :laugh:
He didnt have
1) A hat
2) reflective vest while directing traffic
3) Shoulder lapels.
I went on the argument he looked like a hot and bothered bus driver.
And winner to me :(
The judge actually hammered him. He had been in the force for 20 years and should have known better.
Power to the people :laugh:
It sounds like you've spent more time in court than me Ash ;)
While you're out looking for Decemberween gifts, might I suggest that you consider buying him a hat of some sort?
Underpants as headwear is SO last year. (and it doesn't really impress the ladies) :laugh:
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
