Hey guys,
Just wondering if anyone can give me a few clues as to why my r33 gts-t is hard to start in the morning?
Its got a fuel reg, boost control valve, and a front mount, but it has had brand new coil packs and plugs (splitfire) and everything else seems to be normal, it recently had a tune so its not running rough or idling bad, its just that when i go out in the morning to start my car, i have to pump the accelerator pedal a bit to get it going, it almost seems like a fuel pump or oil pressure problem or something!
I'm just guessing though so if anyone could shed some light i would greatly appreciate it!
Cheers, Jared
:rofl:
https://www.sau.com.au/forums/topic/147177-cold-starts/
I had the same issue with mine, but mine started to happen after the engine over heated and turned off. To get mine back sort of working alright now. Ive so far done the following.
Cleaned the AAC valve as per the Maintenance tutorial - made idle a lot smoother and drive smoother as well.
Changed the idle to a but higher than normal.
Changed sparkies
Did a pressure test to find out i was losing pressure on all cylinders after the overheat (hate this one)
For now it starts fine and idles good and still has the grunt but not as much as before. Hope this helps
https://www.sau.com.au/forums/topic/147177-cold-starts/#findComment-2750133
Have you been using it as a daily driver?
Ive noticed that with mine, after using it as a daily driver, it becomes harder to start also, *have to give it a bit of gas* to start it.
Ive found that, if i dont drive it everyday, Problem goes away? strange but true.
https://www.sau.com.au/forums/topic/147177-cold-starts/#findComment-2753067
this is a very out there thought, but it may be a dribbly injector that is letting a tiny amount of fuel into the cylinder when the car is off.
another out there possibility is that it may be that you have a head gasket on its way out and water is getting into the cylinders.
https://www.sau.com.au/forums/topic/147177-cold-starts/#findComment-2760119
I got told sparks, and iinjects. got new set of Niridium spark plugs, and got my injects, cleaned, properly, in the that special bath thingo. they checked the flows on the injects too, all perfect.
Problem still there.
its a pain in the a$$, when mechanics guess, and you pay.
where is this ACC valve? i been hearing about?
https://www.sau.com.au/forums/topic/147177-cold-starts/#findComment-2760286
the aac is at the back of the intake plenum. its at the top. that doesn't control the cold start function though.
the iac is under the plenum below the aac. much harder to get to.
also i would recommend not using iridium plugs. they don't seem to last any longer or perform any better. they just cost more. i pulled a set of iridiums out of 180sx the other day that were dead after about 7000ks. the coppers i've had in my car are still running fine after 5000ks. i'm going to replace them at the next oil change in a few weeks time, but you can buy a full set of coppers for about the price of 1 iridium plug, and they last nearly as long.
https://www.sau.com.au/forums/topic/147177-cold-starts/#findComment-2760500
Unless you have a tunable ECU you can't 'tune' the car...Only check/change things like ignition timing, s/plugs, coils, clean air flow meter, air filter, check compression etc...
All in all i'd be biting the bullet and taking it to a reliable mechanic to properly inspect the car and diagnose the problem. Its next to impossible to work out what a problem is without a trained pair of eyes seeing the car. Just because someone else had a hard to start problem doesnt mean its got anything in common with yours and its a waste of time guessing.
Edited by Godzilla32
https://www.sau.com.au/forums/topic/147177-cold-starts/#findComment-2761684
i agree with you about the fact that this problem may be completely different to someone elses, but i don't think it is a waste of time guessing. if you can sort the problem out without spending money then you are ahead. if all else fails then take it to a professional.
https://www.sau.com.au/forums/topic/147177-cold-starts/#findComment-2761718
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
