From the Westdrift website
Firstly a big THANK YOU goes out to all those people that have donated money and time to make such an event like this possible. Also to Speedworks for there efforts towards the day.
Westdrift is proud to announce that we have a Collie Track day/Drift training on the
10th February 2007
And are looking at taking full advantage of the day.
We will be looking at conducting a Training exercise in the morning followed by some quality track time.
The numbers will be strictly limited, at this stage we are looking at maximum of 25 trainees to keep track time to a maximum
We are looking at having 5 or more instructors, including Borneo, Keithy, Drift Mike, Clint, Kizza and hopefully gtrken (if he is available)
We will be utilising the skid pan and sections of the track for basics, hand brake turns, 180s, 360s and figure eights, then moving on to using the whole track
Costs at this stage will be
$40 for gold members
$80 for non-members - non-members can pay an extra $10 to upgrade to gold membership
(NOTE: these prices are heavily subsidised by the club)
Included in this price is payment for the camping ground for a bbq and drinks at night, followed by a cruise back to Perth the next day. So don't forget your tent!
If you have any questions feel free to ask them, as the Westdrift Committee will be more than happy to answer them.
Westdrift looks forward to having you there
Regards
Westdrift Committee
The day is split into 2 halfs, the first with an instructor the second an all out drift practice so if for some reason your not keen on having an instructor you can still go out by yourself and enjoy the Collie racetrack!
for more info please checkout the official post at:
http://www.westdrift.com/forum/viewtopic.php?t=740
https://www.sau.com.au/forums/topic/147185-drift-training-day/
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
