Hi all...
Have all r32gtr´s Srsairbags on the drivers side and hicas?
Cant you all list all of the original mods on your cars in this thread!?!
HAve on mine paper fron nissan japan and it says: Build year: 1994/8 And modell year of the car: 1995 and it have srs airbag on the drivers side and hicas.
Have heard the r32gtr doesent have this modds originally and it is weary rare to get!?!?! HAve i heard wrong?
Regards Klaus
https://www.sau.com.au/forums/topic/14719-r32gtr/
Originally posted by ylwgtr2
i have a gtr owners book with all build nos and dates at home in aust...will check wen i get there....but 95 r32...not right...theyy were not called 95 model,nor were they produced then
I can fax you the profe.... if you whant?
In the certificate from NISSAN JP it says: Build Year: 1994/8 And modell year of the car: 1995 Have allsow read in the net that year it would be special ordered R32GTR in the amount of 225 Build....
Im getting a really big suprise when i opened the paper from nissan jp.
:D :bahaha: ;)
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298360
Originally posted by fatz
chassi number will tell the truth
pete
and some had airbags but they r shit (large steering wheel not much room for the driver)
It would be the smallest airbag done in a car, it is a gtr steering wheel in my car...
Yupp it would do that...
Cheers
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298797
Originally posted by craz0
They go buy the first year it was registered so you will probably find that it was first registered in 95 but was made in 94.
Yes made Year is 1994-08 that have i said all the time butt NISSAN japan has sent all documents of the car to my contact over here at NISSAN Sweden and when i got it it says like this: (Once more) Built in 1994-08 and medell year of the car is: 1995 i dont like to be called to lie but its stand so in the paper of it, it is for real.....
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298809
1 way to check...chassis no.....noone said your a lier....i think your missinformed tho..i have seen hundreds of gtr go to auction limited models,automatic gtrs...and have a database here in the office of the auctions all over japan....never seen a 95 R32
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-298838
No not called, ill whant you dont belive i am a lier onle.... =)
It is way strange beqause i had get the paper from Nissan japan and they should now their stuff... but i can have bin missinformd me to.... How can you chek this up?!
This modell should be one of 225 made... but how to se that then?
Regards Klaus
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-299278
Originally posted by KILLER-T
This is a bit odd to me because there is another dude on the forums that says that he has a 95 R32 GTR  and he is from Sweden aswell
It is the same person me and him =) On SAU is my nick: SkylineMannen and on SDU is my nick: Skyline Dude :bahaha: :bahaha:
https://www.sau.com.au/forums/topic/14719-r32gtr/#findComment-300596
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
