Official Sau Qld Dyno Day
Col-GTSX
  • Replies 392
okedoke...our car will be done by that day...so put me down please :yes:
If there is a spot available. The list says there is some spots free, so ive paid. Should be turning a little over 250 too.
Edited by r33_racer
OK all updated...
Time to get money into the SAU account people...
There are 2 spots left on the pre-run sheet... I dont want to bump people off the list to make way for people who are paying now...
Remember your spot is not reserved until SMR33 confirms your payment...
So plz get your transfers done asap...
Ill get a friend of mine to take it for me. Looks like works sending me away for 2 months up north QLD
Sweet... Ill email you the link to the utube video of it going hard...
oh yeah forgot to ask
Is my car going to have problems getting on the dyno with how low it is ??
Nah, its an in ground dyno, so not going to be a problem...
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
