  • Replies 392
Thanks guys...
I have the radiator cap on nice and tight (shane) and will run the car reguardless of if i get the chance to wash it or not... :)
I will be pushing 18psi and hope to crack a nice level 285rwkw on Richards dyno...
I know its got 300rwkw in it as we found it last weekend, however the motor is not going to take that beating standing up...
So i reckon ill get 285rwkw @ 18psi...
OK ITS ON TOMORROW!!!
Remember to have a brush over the first thread and make sure you know the deal...
If you have any questions please feel free to approach me tomorrow...
If you dont know who I am, then ask the people at the bbq and they will point you in my direction...
Most important have fun... See you all there tomorrow...
Aww. my Stupid Turbo is too Stupid big and it surges under load. and hence will just start surging in 4th gear on the dyno. So i think i wont even be able to put her on the dyno..
Im pretty cut because i was all excited. But im still going to come and watch you all lay out the numbers and have a good time with you all.
See you all tomorrow. Adz
Thanks guys...
I have the radiator cap on nice and tight (shane) and will run the car reguardless of if i get the chance to wash it or not... :wave:
col, it's gonna throw a rod without me even touching it :(
P.S me and dan have a lil bet going :D
Me + you
It's on little man.
http://www.skylinesaustralia.com/forums/in...=116562&hl= here is the results from last time incase anyone needs some points comparison :(
Yeah, see last year i only ran 198rwkw... So hopefully i canbreak that record...
well il be driving down in my car, to watch, my mate is putting his on dyno. my car willstay filthy until itstops raining damn it im not washing it for it to just go and rain on it again.
cyas all 2moro. :(
Edited by 85URK
it's a stock standard no mods rb25 N/A running vpower racing
aparrently around the 150/160 kw region
should be interesting
NA RB30 + extractors & exhaust. So I'm guessing around 125kw at the fly
Or around 93-95rwkw. Woot!
See ya's there
Guest
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
