F.s Wrecking R33 Gtst Series 2 1997 Model
By GabsReDeal · Posted
Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders. -
Nice, let me know how you find the 98 tune -
Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
By PotatoCake · Posted
Ah, should have been clearer. Currently has a flex sensor installed all good to go. like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho… -
Duncan , the plan is to get the down pipes done then I book it in for the full tune . Most likely late May , that's the plan.
