I got a gizzmo, and it is easy to turne and setup, easy to plug in, but if you have boost creep issues it's not the best. I have a stork R33 turbo, but all the modds pulling 200rwKw and the stock wastgat is to small to flow enough gass through it, and hence creep. This means that the Gizzmo can't accomodat for so much creep, and you don't get full boost controll. But it's an easy fix, once i port the wastegate. I think is a great unit.
https://www.sau.com.au/forums/topic/147271-need-ebc/#findComment-2748668
Ive got a turbosmart E-Boost 2, heaps of set up options, you can map boost VS RPM (needs to be connected to RPM signal), hold waste gate closed to aid spool up, can be set up to use dual solenoids for twin turbo setups. Can be set for overboost. Audible and Visual alarms. External Triggers. Display 3 diff types of pressure PSI/KPa/BAR. Mounts in a guage cup. Very versatile unit many options.
I have the 60mm sleeper edition, mounted where my cigarette lighter used to be. Need access to a dyno to setup properly though. $619 (i think) with freight to WA from CRD.
My 2c
Evil
https://www.sau.com.au/forums/topic/147271-need-ebc/#findComment-2749865
