  • Replies 56
iv got the same problem at high revs in my s2 33 going from 3rd to 4th aswell, and once it has done it going from 4th to 5th, i went to a couple of places and they sed it might be cheaper to get a new box :P they say it a lot of work replacing the syncros ;) i brought up that changing the oil to redline will stop it but they sed it will just hide the noise and will result in the gearbox needing a rebuild down the track
i have yet to go to a few other places and suss it out :huh:
I had a similar problem in my 33. Was crunching slightly going into second and third... i put in Redline Shockproof (yeah the blue stuff... red bottle if i remember correctly) and after a few days the crunching completely went away. It is heaps better to get into any gear and certainly justifies the cost (i think it was like $125 for the bottle or something :laugh:)
Just my 2c :)
very common problem for skylines to crunch going into high gears at high RPM. My R33 has very low k's and even with good synthetic Motul gear oil it isn't perfect into 5th at big speeds (and the Motul was still a big improvement over the original gear oil!).
Ill try the redline blue stuff and get back to you all.By the way i just had a new clutch fitted,when the box came out they found the clutch pivot pin at the bottom.It had sheered in half.Took forever to find another one.Now the crunching is worse into 5th anything over 2000rpm an it will crunch.So now im driving like a grandma until i can figure something out.
well one would ask where you would be redlining 4th anyway.. im going to assume a track or dragstrip..
Redline shockproof oil is not recommended for gearboxes with syncros... even redline state this.
Castrol VMX80 is a better alternative.. all you're really doing is masking a problem that ultimately needs to be fixed
Just a quick question. I dont have anything wrong with my GB. But i got some VMX80 cause i am planing to change the oil. Will this make the GB worse if there is nothing wrong with it in the first place?
at high speeds I sometimes crunch going into 4th, but only really at 150 or more, so it doesnt really phase me as a rarley see that sort of speed.
If im paitent on the gear change it go's in fine anyway. I just dont think the synchros can keep up at thoes speeds.
No, VMX80 has been tried and recommended by many people on here.
My S2 had a genuine 34,000km on it when I bought it and I noticed a marked IMPROVEMENT when I dumped the factory oil and filled it up with Motul Gear 300. You will probably notice a difference in shifting quality when you put fresh oil in, too.
Yes it is very annoying, my car crunches in forth when entered with high rpm from either second or third, anything over about 4k and crrruuuunnnncchhhh, even when i wait a while with the clutch pedal depressed and still crunch.
I put the redline oil in and found it makes gear changes generally smoother put only really masks the problem as it definately did not go away. Anyone know how much new synchro's would be to put in? or how much a rebuild is?
the RB25DET boxes have dual synchros 1st-3rd and single synchro 4th-5th, 4th seems to be very common synchro to let go in these boxes.
Cost of rebuilding varies greatly depending on what is needed. If you are replacing all bearings and couple of synchros expect to pay just under 1K or up to 1.5K for all new synchros. (plus R&R of box itself)
  • 3 weeks later...
The 33 box is common for this, the fourth gear synchro gets a little tired and eventually wears the input shaft. If you are hard enough on them the selector fork will break in half. I rebuilt one with new bearings, synchros and 3rd/4th selector fork and it lasted just over 12 months, in the end it broke another selector because the worn input shaft wouldnt allow a smooth meshing.
^ how much did it cost?
if you have f**ked synchros and are prepared to have it rebuilt.
as if you would choose the same damn gearbox!
i dont know exactly what a good gear box ugrade would be for the 33 but its not practical to put the same gear box back in and rebuild it... obviously the 33 synchros cant handle the shifts
my 33 got this problem from fast 1st - 2nd shifting. now it crunches slightly only when i shift as quick as i can.
but that was my old car.. i have a new 1 now doesnt crunch but it hasnt been given anything yet.
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
