That would explain why a slightly moded jap spec will spank an aussie version with the same mods. however start changin the oz spec engine managment and u have the identical car!
Don't forget guys with the aus version S15 if you go for an aftermarket ecu,
Eg: Apexi Power FC you have to switch wire 30/31 on ecu wiring harness to run the fuel pump & i think the CAS.
:D
jap spec has bigger injectors, and a 6 bolt roller bearing turbo compared to the aussie 5 bolt. the steering wheels are nicer in the jap spec, the exhaust in both is very simiar and from my experience the difference in boost is minimal if at all different. ice performance have told me that the most they are able to speeze out of the aussie spec is about 180rwkw and jap spec more like 215rwkw. I have witnessed first hand two of my freinds going at it. one had a stock japspec the other an aussie spec with catback exhaust, and the japspec raped it everytime
  • 14 years later...
Australia is also hotter and has shitter fuel, so the ADM version has less timing in it. Another reason why you see stock turbo JDM S15 crack ring lands when kids ram in 1 bar of boost with the stock ECU/tune and go to Mexico.
Jdm makes 184kw@fly. Adm makes 147kw@fly.
As noted above Jdm has more timing advance.
Jdm has digital climate control, adm is analogue.
The Jdm's imported where the pre Adm years so i think that was 99 and maybe early 2000.
I wouldn't worry about which one, just buy the best condition example you find. Personally i favour the Adm version as there is less chance of the odometer being wound back and less chance of rust due to climate conditions. They are things to definitely check for on either model.
7 minutes ago, r32-25t said:
Aussie versions of cars also end up with factory immobilizors where the Japanese ones won’t
Then you install a JDM ECU, swap the 2x CAS pins and 1x fuel trigger and off you go - or BYO Haltech/Link/MoTec/ etc.
Poor effort on the NATS lol.
My stock NA 86 makes more @fw than the ADM S15.
I don't want to talk anymore about this though......
I like my 86, but I lay awake at night thinking of what could have been.......
Yep, except an s15 can make 200rwkw tuned and around 220rwkw on e85.
  • Sad 1
As stated, I don't want to talk about it.
Sadly I missed a ultra low km one owner ADM when I was looking.
The thing was like new, stored, it had 5000km on it if I recall right, it sold for $28k I believe, which I would have paid.
It was red, a yellow one, exact same condition, owned by the same guy sold about 2 months prior.
I doubt I will ever see one in that condition again.
Bugger
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
