go the gt2860r ike
I assume you mean gt2860r-5 what are the gt2860r-7's like slightly less hp but more response??
yeah the price difference would be a set of hks dump pipes apparently the actuators on the gt-ss are 50%
stronger according to the blurb. Do the garretts have the same actuators just for better boost control that is
Does anyone know if you have to pay duty on stuff from overseas, maybe better to haggle locally for those garrets but which ones.
all da best
  • Replies 157
Posted Images
^^^^^^^^any more news on ya power levels.or ya still looking for gearbox mate?
also what did yo do to modify the oil returns,just re-drill the whole to fit.????
I removed all the broken teeth from my box and have been driving -around with no 3rd. Looks like I have an OS box lined up.
I have recieved my FC-Datalogic so been doing some tunning. No idea on power levels, however boost response is insane and dataloging indicates faster accel between 1st and second with 1.4bar.
good response that unreal hope to be installing mine today. but still have other things to do so sadly no start up..
so sounds like your happy with the turbos then
thanks boostd,yeh i thought thats what i had to do(elongate)holes.
as i dont have hks turbos b4,will i need to change the part your talking about.also some said in another thread i was reading,that oil restrictors will need to be put in place with ball bearing turbos. something about seals blowing otherwise?
Yes this is interesting. I posted a question about restrictors many months ago and got varied results on the answers.. What I can tell you though is that I replaced std GTR turbos with Garrett 2860R (the 707160-7's) and went racing.. 5 laps into it I had blown the oil seal on the front turbo... Whether this was a symptom of another fault - or whether this was due simply to high oil pressure I am not sure..
On the Garrett Website under the FAQ though, it does mention the 'best' oil pressure to have for Ball-Bearing types:
http://www.turbobygarrett.com/turbobygarre...r/faqs.html#t16
It would be good to be able to measure or regulate the pressure at the turbos - but I don't want to simply fit a restrictor and then under supply them...
Anyone know the real answer to this?
BB turbs generally need half the oil supply of a bush type turbo, so a restrictor would be recommended if changing to a BB turbo.
Some companies would sell restrictors for oil lines, can't think of any off the top of my head.
On that note, can anyone elaborate:
R34 GTR BB turbos would have to have a restrictor or smaller oil inlet hole?
I remember my GT30 had an internal oil restrictor on the cartridge.
I would assume other Garrett turbos would be the same... i didnt blow a seal on my single...
and not with gt-ss, far as im aware we have not added any restrictor either
thats good to hear,cause ill be putting my turbos on this week i hope. but if anyone has the 2860r on there car and has put some sort of oil restrictor in could please advice us,cheers
UPDATE: I decided to purchase a new set of Garrett 2860R -5 and managed to pull a 274kw @ 16psi.
I was hoping to pull 300kw...Car has cat back exhaust, front pipes, dump pipes, Power FC, Gizmo Boost Controller and Bosch 040 Fuel Pump.
Oh Well.........I think a TRUST T78 is on the list now *S*
What size injectors are you using Gavin
Great news JUN....Cam gears would help you get a bit more and earlier, high flow or *cough* spec R cat would help too. Intake? Pods?? I have the -5's and they get it done...
we just put the garret - 5 on our car, havnt got it dyno'd yet but just pulls from 3500 all the way up to 8.
feels about 300kw or so. but until we get it dyno'd and a good computer who knows
cheers
Nick, I have the std 440cc injectors in the car atm.
Do you think a replacement cat would help? any good recommendations on where to get one?
I have 2 x Pod Filters...unsure of brand.
Not sure of which cam gears to get....leaning towards Tomei ones over the HKS ones.
Edited by JUN R33
If you are using factory injectors then 270+ kw at 16psi is impressive.
Without knowing the rest of the specifics about your setup, fit some larger injectors and up the boost and you will hit 300 without much trouble.
If you dont have cams already, Tomei sells a bundle with their Type B poncams and cam gears at a pretty decent price.
Tomei and HKS cam gears are much of a muchness now, the new HKS design is far improved over the old ones which had a bad tendancy to wear around the teeth.
Yep....Std 440cc injectors but, I just expected more then 270+ *S*
The car is pretty much standard except for the items I mentioned earlier.
My tuner said the car did make 300kw but, it wasnt at an acceptable level of tune....was tuned safe and made the 274 run.
I'd rather be safe then sorry.
I have a dyno sheet which I hope to have up by tomorrow for all to look at.
LOL you have a Power FC take the car for a run and have a look at what the duty cycle hits and then you will know what Blitz means. Its common knowlegde that stock fuels system runs out of puff around 260-270kws.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
