:) Now you should go in a car with 2860R's and tell us what you think...
Yes I changed from T517Z's to 2860R's..
Yes I have MUCH more response..
The T517Z's were good for top end, more suited to drag racing, will make good peak power...
No I wouldn't change them for anything.....
No I wouldn't buy HKS items, the price of the Garretts are too good refuse...
Ive been in the same gtr and driven it with the 517's....havent seen the 2860R's in a gtr infromt of me so havent had a chance to see in in action, having said that cant knock the 517's as they seemed to come on nice and early for what they are. I dont doubt they arent as responvice to the 2860, it from the trim size described they would easily.
I dont wanna be made out like a jackass so I thought id have to give another of my 2cents.
Ash, as stated you have been in a car with 2860's thats fine, theres a bit of a difference between sitting in a passenger seat and driving a car, so I cant see why you disregard the 517's so fast...I guess it all depends how you drive the car aswell....
each to their own....anyone wanna give me a ride in a 2860 powered GTR? So I can see what all the fuss and a fuedin is about? :)
peace
Jez
  • Replies 157
Posted Images
each to their own....anyone wanna give me a ride in a 2860 powered GTR? So I can see what all the fuss and a fuedin is about? :/
peace
Jez
I have dyno sheets to prove the response differences, will try and dig them up...
JAGR33 which version 2860r did u buy -7 or -5?ive just purchased the -5 and im very interested to see your dyno results.
ill be hoping to make 300awkw with pfc,044,tomei 600cc,cooler,full 3inch zorst etc etc
I have the -5's, you should achieve your desired power target, it all depends on whether its standard motor or rebuilt, cams, boost level etc....
Your exhaust and injectors will restrict you a little....
I'm at around 350rwkws on 20psi...
600cc should see 300awkw,and as far as exhaust i just purchased a 3 1/4 inch full titanium,and ill have stainless dumps and fronts so should be fine id say..
stock motor but will have cam gears...
a mate i no has the same setup but with -7 making 300awkw and he has 550cc injectors...
i wouldn't chose either. for low mount turbos for me it's either HKS GT-SS, HKS GT-2530 or Nissan R34 GTR N1 depending on exactly want you want from the car.
The GT28060R-5's are nearly identical to the HKS GT2530's.
I would personally go the Garrett if i were comparing the two.
Listed are the HKS GTSS specs also which uses the same turbine as the GT2530's but slightly smaller compressor wheel although the GT2530's much like the GT2860R's turbines are usually clipped to increase exhaust flow.
Compressor
HKS GT2530
Trim :63
A/R :0.60
Ind :47.7mm
Exd :60.1mm
Garrett GT2860R-5
Trim :62
A/R :0.60
Ind :47.2mm
Exd :60.0mm
Turbine
HKS GT2530
Trim :76
A/R :0.64
Major :53.8mm
Exd :47.0mm
Garrett GT2860R-5
Trim :76
A/R :0.64
Major :53.8mm
Compressor
HKS GTSS
Trim :60
A/R :0.60
Ind :46.6mm
Exd :60.1mm
Turbine
HKS GTSS
Trim :76
A/R :0.64
Major :53.8mm
Exd :47.0mm
Compressor
HKS GT2530
Trim :63
A/R :0.60
Ind :47.7mm
Exd :60.1mm
Garrett GT2860R-5
Trim :62
A/R :0.60
Ind :47.2mm
Exd :60.0mm
Turbine
HKS GT2530
Trim :76
A/R :0.64
Major :53.8mm
Exd :47.0mm
Garrett GT2860R-5
Trim :76
A/R :0.64
Major :53.8mm
Compressor
HKS GTSS
Trim :60
A/R :0.60
Ind :46.6mm
Exd :60.1mm
Turbine
HKS GTSS
Trim :76
A/R :0.64
Major :53.8mm
Exd :47.0mm
yeh i went the -5 as cheaper option th getting hks 2530 or even the gt-ss
OK I have found the graphs, but my scanner is playing up so here's a rough comparison:
The dyno runs were done on a dyno dynamics dyno in 4th gear (R33 GTR) and in the same mode (non-shootout)..
At 95km/h, the T517Z's were making 85kw, the 2860R's 95kw
At 112km/h, 105kw compared to 140kw
At 128km/h, 155kw compared to 240kw :)
At 145km/h, 255kw compared to 305kw
At 160km/h, 330kw compared to 325kw
At 178km/h, 360kw compared to 350kw
At 194km/h, 365kw compared to 358kw
These figures were taken from a dyno reading AT THE REAR WHEELS.
The same dyno was used.
The car essentially had the same components, same exhaust, cams, ecu etc...
As you can see the T517Z's were no match down low and midrange of the 2860R's is phenomenal..
Though when the T517Z's finally do wake up, they make quite good power..
I prefer higher average power than higher top end power...
Others might like the waiting and then big rush of the turbo spooling at full boost.
The 2860R's have a more progressive power delivery..
From the graph its evident which are more responsive...
Hope that helps...
P.S once the scanner is sorted, I'll post up the graphs...
Just a note...
The GT-SS specs you listed are in fact SR20 Gt-SS specs..
The GTR specific Gt-SS are quite a bit smaller ...much more like R34 N1 or -7 Garretts.
cheers,
Ben
Compressor
HKS GT2530
Trim :63
A/R :0.60
Ind :47.7mm
Exd :60.1mm
Garrett GT2860R-5
Trim :62
A/R :0.60
Ind :47.2mm
Exd :60.0mm
Turbine
HKS GT2530
Trim :76
A/R :0.64
Major :53.8mm
Exd :47.0mm
Garrett GT2860R-5
Trim :76
A/R :0.64
Major :53.8mm
Compressor
HKS GTSS
Trim :60
A/R :0.60
Ind :46.6mm
Exd :60.1mm
Turbine
HKS GTSS
Trim :76
A/R :0.64
Major :53.8mm
Exd :47.0mm
Too many numbers everyday.
Both are still rated at 320ps
GTR
HKS GTSS
Trim :56
A/R :0.60
Ind :44.46mm
Exd :59.41mm
Turbine
HKS GTSS
Trim :62
A/R :0.64
Major :53.85mm
Exd :42.40mm
Still Garrett is the better all round option for cost-power
Hey all,
I own the GTR Wheezy drove. I cant agree more with him in the responsive sense. The T517z(atleast for me) is a smooth turbo. I have no problems driving it on the street and track. My experience from this turbo set up has shown me that its perfect if you want various uses from the car.
List of mods...... Twin trust T517z's
Greddy combined front/dump
Blitz Nur spec cat back
Bltz twin pod filters
Greddy profec B boost controller
OS Geikin twin plate clutch
Results from these mods are response with power right through rev range. Havent lost a street drag to date :) Haha, just joking
Catch!!
Well I have already made the choice and gone for the GT2860-5.
Done the drive thing on a car here in the west with -5 well set up and it was very impressive to say the least.
At the price they seem hard to beat.
With any luck I can do a before and after sometime in the new year and post the results.
Reliability mods going in as well - PFC + EBC, timing belt, sump baffle, oil cooler + relocation kit, 700cc inj, adj cam wheels, new custom dumps/front pipes, high flow cat, JB clutch and new gaskets (thanks to a leaking plenum that started this process in the first place). By by $$$$$. :laugh:
Excellent comparison Jack.
No problems at all...with the cam gears and a sound engine.
sweet as,will wait and see what the motor does..fingers crossed
BOOSTD very interested in your finding. When will you be expecting to dyno?
will expect to be on the dyno during the first week in january. I'll run the same boost level and afr.
here's a link to my last dyno
http://www.skylinesaustralia.com/forums/in...st&id=60458
Edited by BOOSTD
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
