  • Replies 45
I took the heat shield off to get the photo. I would just like to know for sure what it is. Even if i know whether it's stock or whether it's not is good enough for me. Nick from APC said it was aftermarket but didn't know what it was...but he was looking with the heat shield on. So who knows...
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-299978
Hi MM2, the high flowed R33 RB25DET turbo on our R32 GTST RB20DET says "16V 5 Nissan Motor" on the compressor cover.
I have seen a number of R32 GTST's with R33 GTST turbos fitted, so this may help if yours is another one.
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-302258
OK, i managed to read what i think it says on the compressor cover with one of those little mirrors on a rod (don't know the name of it). Reading clockwise around the cover it says:
M27 (with a circle around it) 2 1-1 A/R 80 (i think) GARRET.
Any ideas what turbo it could be?
Regards,
Scott
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-302582
My 2510 has M27 and .60 cast onm the front, it also has a machined front with 4 allen key nuts on the front. I don't think yours is stock, as it doesn't have the factory 90 cast section from the compressor cover on it.
More pics would help
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-303329
only akin 150rwkw it aint gunah be anything huge
firstly put on a heat shield though, thats gunah be boiling the engine bay as it is
the actuator is in the std position
i have a 0.60 comp housing and it rubs against the chassis rails so judging by that pic it aint that big...
id dare say from size and power output its either a small GT series turbo or a high-flow.
easiest way to find out is pull the intercooler piping off and take some better pics for us
also if the car hasnt got a front mount (or theres no evidence of it ever having one ie cut up front supports or front bar) then i doubt its anything huge
https://www.sau.com.au/forums/topic/14734-turbo-id/#findComment-303661
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
