As per title guys have the following I want to get rid off as its not required. I know I had the rb26 block for sale previously but I was f**ked around by someone in sydney something fierce so now its back up, 4wd sump is being used by me but.
VG30 turbo - good condition perfect for 20/25 upgrade - SOLD
RB25 R33 head - low k's 40,000 with VVT, cams, valves, stem seals etc, rocker covers, and possibly the valley cover, cas
too (Will need to be re-faced as it has had a repair to the very corner of the head. VVT has been modded already to suit rb30 block with external feed. - $400
RB20 Silvertop turbo - no shaft play excellent condition - $150
RB26 bottom end complete minus 4wd sump 90,000k's- $550 (dis-assembled)
Looking to sell some this weekend guys so I will listen to any offer you wish to make as all this stuff is no longer required.
Cheers.
Edited by James_03
hey mate you in brisbane im interested in the turbo and would you sell the 26 crank and rods seperate if so what condition they in.
thanks scott
Im in Browns Plains/Regence Park, Brisbane southside.
Price drop on the complete bottom end guys $550 come and get it. Now thats pretty damn good as I just need the thing gone.
Also head is now $400.
The RB26 bottom end is fine, removed for a 3ltr conversion. I can get pics of the RB25 head if req, it just needs to be faced like you would prior to fitting any head.
Cheers.
Edited by James_03
james can you please send me your phone number via pm re: bottom end.
thanks.
How much damage is done on the head and what is required to repair?
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
