  jetpilot said:
I changed the fuel filter at 100, 000km and the car has now done 137,400...is it due or do they last for 100,000km
I think your getting confused with the timing belt mate. Fuel filter should be changed approx. every 5000 to 10000kms. Oil filter should be changed approx. every 5000Kms. Timing belt is a major service which is usually changed every 100,000Kms with the idlers and tensioners i believe. Good luck :laugh:
i don't think you need to change your fuel filter that often.
it depends on how often you run on a low tank. if you don't let the car get below about 1/3 tank then you can leave it longer than someone who constantly runs it below 1/4 tank.
Edited by mad082
I thought the fuel pump sucks fuel from the bottom of the tank anyway.?.
I agree with GTR chick, every 4000km's is a nice ammount.
I just dont understand how people put off chaning their oil every 5-10,000km's.
Its a $45 bottle of oil for gods sake, its cheap insurance, i keep my baby bathing in new motul every 3000kms.
probably less if i involve spirited driving.
cheers
Mine swallows $60 worth of Motul every 5000km's + a $16 PureOne oil filter.
Every fuel filter I do the airfilter also (Purulator airfilter)
Still running the stock airbox but with a nice big arsed 100mm cai.
if i did mine every 3000k's that would be after only putting through 500L. seems kind of a waste. if you used a handfull of gravel as octane boost then i could understand changing it as often as your oil.
to see how little fuel that is, a common fridge is about about 450L. so if you had a tank the size of your fridge you would be changing it after only putting through that small amount of fuel.
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
