Hi all,
i have just done a custom air intake on my R32.
It make use of the space reserve for the stock intercooler.
Problem with this one is driving on highway when rainning.
The water mist created by the car in front always make the filter wet. Thinking of adding some grill to prevent too much mist entering.
Driving on normal road where water mist is not as bad seem no problem.
https://www.sau.com.au/forums/topic/14738-custom-air-intakepic-attached/
Sorry to tell u this but it would of been far better to leave the filter where it was a and then make a CAI to it.
Using ur theory on the water spraying into the filter. Well imagine if a small rock or many get into the filter, then into your engine. Bye bye engine.
The Pipe work is going down and also i dun have problem with stone. Further more most cone type filter have metal net protecting it.
Its the Mist that got spray out of the tires from the car in front. That might be bad. use vent to guide the wind away from the filter but into the box will solve the problem but where can i get such things? Maybe just put wire mess???
Putting the filter in the engine bay is the first choice but u get plenty of hot air from the RB engine. So putting it at inside the small air box will be prefer near 100% Outside Temp Air.
the air it will be sucking will be heaps cooler than in the engine bay, even compaired to ppl with partitions. but i would be so worried about things hitting the filter and as u say water.
im happy to duct the cold air up to mine. saves the stess.
Hi Lambo. Nice work. I actually did the very same thing with my '33 a few months ago, although I think I went to a bit more trouble than you. I have no problems with water mist, wet filter syndrome or rock/stone damage. Just fresh ocean breezes. Made from stainless steel 3 inch mandrel bend, welded to a stainless flange which matches the air-flow meter flange. It was then powder coated in a semi-gloss black to match the finish of the air-flow meter. After a quick "driving-in-the-rain", problem areas were shielded with thin rubber matts.
This set up works just as well if not better than CAI's (worked better than my CAI, which was a great setup in the first place) and it gets rid of the, in my opinion, yucky box in the corner of the engine bay.
Obviously this kind of thing isnt really necessary, but for people like me and Lambo, we like making shit, and being slightly different.
Here's my illustrated documentry i digged out of my PC.
Rock on Lambo... you're a genius! :)
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
