Hi,
Whats the filter for that tank on the left side of the engine?
Is it a Surge Tank?
I am thinking of adding some Grill with Vents that guide the air to the left side of the hold. This way all the water mist will be block off by it and non will actually get to the filter.
Dunno where can i get one done thought..
Lambo, tis an oil catch can.
I dont like where it is though... in fact i dont even like the thing altogether. its way bigger than it needs to be, and just clutters up the engine bay.
as far as diverting blow-by from your inlet, if youre not using a proper (legal) separator, you may as well skip buying a catch can and lead the breather hoses under the bloody car. its a defect either way, and the latter is much neater.
as to your problem... if you ask me, you simply need a deflector to shield the pod from direct water spray and debrit. i dont believe vents are necessary as air will be sucked into the pod from anywhere and everywhere. the cooler air outside the engine bay does not need to be blowing onto the pod, as long as the pod is out of the engine bay, the cooler air wil be sucked into the pod from all directions. If youre planning to make it yourself, dont make it more complicated than it needs to be.
good luck.
oh, do you like my turbos? :(
Lambo, a fine mesh filter will help stop large sprays of water hitting the filter, but you will also need to make sure the filter itself is still water resistant.
I'm not sure what filter you have there right now, but I think the Blitz filter is made of a fine mesh metal itself. That could be the way to go from there. Just be wary of rust ;)
Hi Instant.
I was very vigilant when it came to monitoring the setup for the first few weeks, and the filter remained completely dry on every occasion.
I havent had any problems in any rainy weather condition.
But I wont be performing any shallow water crossings.
In regards to the front left tyre, you can see in file, "intake 007.jpg" and "intake 008.jpg", that the filter is completely protected.
Yeah, I have wondered have an officer might say about it, if anything at all. I'll let you know if I'm unfortunate enough to have the experience (touch wood).
See ya.
ive got the same setup
got pulled over 2 weeks ago copper said "wheres ur air filter" i told him "its inside the bar behind the spot light" he goes "well i cant see it as far as im concerened theres no filter there" i told him "have a close look" he says "nup cant see it so from wat i can tell u dont have one"
-i got defected for not having an air filter
-then he said the car was too low with out measuring shit
-then he said the wheels LOOKED too big without checking any numbers
-then my exhaust wasnt standard so he put that down too
apparently half of the parts of my interior were a drefect too but he didnt list em
back to the air filter part he told me that basically if ur filter isnt in an enclosed airbox as standard its a defect because "it creates undue noise and unfavourably alters the cars air/fuel ratio"
