As the title says, yesterday morning my climate control in my r33 series 2 makes a *knock knock knock* noise when ever i turn the car on or change the mode the climate control is running in, i.e windows, to drives legs.
It sounds to me like plastic gears or something is clicking.
When i turn the climte control unit off an on again it usualy goes away, sometimes it clicks for 5 seconds, other times 20 seconds.
Is this a common problem?
Cheers
sounds like something is making the gears sticky, or blocking it, or the gears are slightly stripped. the clicking would be as it tries to change and it is just skipping the gears as it can't move them.
I ran the cable to my boost gauge down the center air vent, that was about 4 months ago, and its been fine since then, now all of a sudden its going it, could the cable have fallen into the gears or something?
Bleh i have to take the dash facia off on the weekend to install a din pocket and remove the hicas bulb so i guess ill try figure it out then.
cheers
It appears to come fron the center vent, where the boost gauge cable runs from, bleh just another thing to try and fix.
Hahaha if ONE single week went by when i didnt have to try cure a random noise in my skyline id die of shock.
cheers
If you do a quick search, it's been covered at least 8 times before that I can remember.
It's more than likely some sprocket thingy on the heaterbox. Mine does it, heaps of R33's do it. Sucks eh? =-]
ahhh FFS!
I was hoping i would just be able to take the dash facia off to get to the problem, removing the ENTIRE dash is waaay to much effort, ill just turn the music up loud when i turn the car on.
Cheers
bro, you need to replace the stepper motor in the aircon assembly...might be costly not really sure. my r33 made that noise before i bought it and said 'fix it!' asnd that what he said he replaced...
When i was looking under the dash today, i noticed down the bottom of the air vent a little black electric box which looked like something that could be causing the clicking noise.
If it is indeed that box thats causing trouble then it wont be hard to remove as is, ill try to get a pic of it.
cheers
cheers
mate i had this exact problem its a little arm joined onto some cogs (gears) what ever u want to call them after time the gears wear out but the arm still trys to move this causes the clicking noise it is big job to do specially for such a small part there is no way at all i could get this part out with out taking the dash out. I probably wouldnt have bothered fixing it but afew weeks later my heater core shit itself and i had coolant pissing inside the car so had to remove the dash for that anyway :laugh:
  • 2 months later...
I just rang up a spare parts place to get a replacement motor and they told me there are TWO stepper motors for the AC! A higher one and a lower one. So..... seeing as noone here as differentiated between them (let alone mention there are two), I had to spring for both, cos I'm getting my stereo guy to fix it, and I don't to pay for him to replace one, only to find it's the other and that he has to go in again. One motor has 8 teeth and the other has 10.. or something like that. Both cost me $125.
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
