Any import parts you want be it engine or panels or accessories
Please call nippon Sydney.
GTR , GTST, Skylines, Silvias 180sx we have it all!
The prices are always cheaper than everybody elses I can gaurantee you that! These guys are close friends so please give them a call guys and tell them that you saw this advertisement on the internet from Minh and you will get a very generous discount. I promise.
Also they do bodykits and car painting as the owner owns Prestige Motorsports in Lansvale too.
Their Number is 0411107654 (Ask for Steve)
Their Address is Chadderton St Lansvale NSW.
Minh (SDU4EVA)
And got the stealth wing porgie, although i've seen better then that one. Does that mean you're gunna get a new exhaust tip ? have you fixed the exhaust yet ?
https://www.sau.com.au/forums/topic/1474-stealth-wing/#findComment-28951
yeah i fixed the mounts last saturday.
i'll be getting the tip right after the wing. i know which one i want, just have to find it. one of my mates has one on a skyline (not on these forums) so when i run into him i'll ask him where he got it from.
I'll call Steve to compare prices, cheers.
what do you mean you've seen better? is there any variations to it?
https://www.sau.com.au/forums/topic/1474-stealth-wing/#findComment-28953
Skyzerr33 has a little drift wing type-thing George, ask him when he gets up there.
It was part of a Bomex kit.
I've liked his ever since he got it - if I was goin to get a kit, I'd get something similar to that. I really like the little lip type spoilers :P
https://www.sau.com.au/forums/topic/1474-stealth-wing/#findComment-29016
pwahaha.. i was considering getting that wing way back when my
cuz had his Burgundy GTST 33 in HPI.. but i've seen too many 33s
with that now.
The "without a wing" looks looks nice.. was considering that, but
in all honesty a white 33 will look better with this option.
ONARUN, get a wing that someone doesn't have yet... :P
https://www.sau.com.au/forums/topic/1474-stealth-wing/#findComment-29377
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
