Just jumping in with a quick red herring, since the usual suspects are on.
Who has CP pistons? I called Rocket for Arias 1.5mmOS for the RB25DETT and they think there will be 8 weeks wait. Personally I'd like to get the block in before that.
Any other alternatives? Wiseco? I have a great report on those in Honda but what about in teh RB's? PM or email if you don't want to whore this thread.
ring Mark Jacobsen for CP's Geoff...PM me if you want his mobile number...Mark can get you Wiseco's too and has had great experience with them as they are not a "heavy breather"
Geoff, I got my CP's from Just Jap in Sydney.
Great pistons.
I thought you said valve clearance, stem to guide clearance is double on the exhaust valves at around 2-3 thou" from memory and about 1-1.5 thou"on the inlet.
wrxhoon i think your missing my whole point which was take to someone who KNOWS rb26 heads and i was basically make quick referrence to some of the gear which is different about the rb26 heads to the normal heads service centers deal with. I was not trying to give exact clearance spec's of the top of my head, as there have been way to many beers sunk since i last spec'd my valve clearances (to guides). All i remember is they are uniquely large clearances on the exhaust side and it catches many people out. Where it's 2-3 thou or 4 thou isn't what this guy is interested in i believe but more the issues he need to deal with to built a strong health rb26.
pete
O i forget get some sump baffles or a new sump if it fits into your bugget.
look for oil control thread by sydkid and get most of that done aswell.
LOL RB26s cheap i wish! Dont think the tomei gaskit kit has everythink you need for a rebuild aswell?
Main thing to remember is anythink you dont do now could cost you another rebuild later.
a rebuild in the future after this current 1 i gotta do is something i really wanna avoid. the problem is i know stuff all about motors and rebuilds.
theres no way im gonna be doing it myself. im leaving it all to a mechanic. i still would like to know some things that i could get done now when the motor is out.
like extrude honing the exhaust manifold. port polish the head. ive read u guys talking about it. as i said above im :/
apart from resizing the valve openings, what else is involved in a port and polish??
what kind of things do i need to get done with the bottom end? i have been led to believe that the bottom end in rb26's are tough as and wont need any work.
sorry for the hijack
Great pistons.
Thankyou gentlemen. I might actually give the Wiseco's a shot, but if I can grab Marks number that would be great Paul. PM sent.
Can I suggest you not install forged pistons. I did in my RB25DET, and I cannot stop it devouring oil.
Forged pistons need to be HOT, and my experience is that normal driving does not seem to introduce enough heat to force the piston to expand properly.
What piston to bore clearances did you use? What pistons?
well fellas
heres a copy of a parts list from a pro engines build that was posted on the site a few moons ago
should be of some use to a few
theres abit to then aye,but i no when i do my biuld ill be doing it right the first time as i dont want to be up for more costs if it lets go..
i use the wiseco pistons 87mm with a 4 thou clearance, invest in some good rod prepping, and get new ARP bolts for the rods, as was said before the stock GTR bolts are well BS. get your cranck checked, and use new bearings allround, i reccomend the ACL black race series, top stuff. and i run the wiseco pistons on 450 AWKW and i drive my car pretty much every day. treat your engine correctly ie good warm up, on time service, let it cool down. and yea owning a RB 26 is like having a super high maintance GF, ie your wallet will be begging for its life :)
well fellas
looks to be well priced and what people should expect to be paying
Mate I just rebuilt my GTR about 6 months ago this is what I did
NISSAN N1 CRANK SHAFT
NISSAN N1 OIL PUMP
NISSAN N1 WATERPUMP
NISSAN GASKET KIT
NISSAN TIMING BELT
EXEDY TWIN PLATE CLUTCH
TOMIE OIL RESTRICTOR
ARIAS FORGED PISTONS
EAGLE RODS
ARP HEAD STUD KIT
COMETIC HEAD GASKET
RESLEAVED BLOCK AND DECK
KING MAIN BEARINGS
KIN BIGEND BEARINGS
PERFORMANCE VALVE SPRINGS
HEAD SERVICED PORT & POLISH AND K LINNERS
SUMP BAFFLES
INJECTOR FLOW TESTING
DRIVE BELTS
NISSAN COOLANT
OIL & FILTERS
HKS 2530 TWIN TURBOS
HKS DUMP PIPES
HKS SUPERDRAGGER SYSTEM
HKS CAMS
OIL COOLER
HIGHFLOW CAT
850CC DENSO INJECTORS
BOSCH FUEL PUMPS
TRUST TWIN PODS
ROM ECU
STRUTE BRACE
REAR SWAY BAR
ENGINE DAMPNER
AFTERMARKET SUSPENSION coils
d jetro
eboost 2
+ OTHER STUFF I'VE FORGOT
BUILT BY TIM @ SIKEMWREX RACING
This setup for 550rwhp daily
Forged pistons do expand but if an engine is built with the right clearances it shouldn't really burn any oil.
I would suggest as Abobob alluded to that the engine wasn't built tight enough.
On the upside- when an engine is built loose it will typically make more power even though it consumes oil. Race engines typically have 6-8 thou bore to piston clearance and chew through the oil but there is less friction and therefore less heat generated which improves the reliability and life of he engine.
  • 1 month later...
Should this be of concern for me? My motor does take a long time to heat up, and you've really got to flog it if you want it to be hot. I don't mind warming my car up for five minutes (I do it anyway) but would that be long enough with forgies.
Do all brands of forged pistons take an equal time to heat up and set into position?
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
