Just jumping in with a quick red herring, since the usual suspects are on.
Who has CP pistons? I called Rocket for Arias 1.5mmOS for the RB25DETT and they think there will be 8 weeks wait. Personally I'd like to get the block in before that.
Any other alternatives? Wiseco? I have a great report on those in Honda but what about in teh RB's? PM or email if you don't want to whore this thread.
ring Mark Jacobsen for CP's Geoff...PM me if you want his mobile number...Mark can get you Wiseco's too and has had great experience with them as they are not a "heavy breather"
Geoff, I got my CP's from Just Jap in Sydney.
Great pistons.
I thought you said valve clearance, stem to guide clearance is double on the exhaust valves at around 2-3 thou" from memory and about 1-1.5 thou"on the inlet.
wrxhoon i think your missing my whole point which was take to someone who KNOWS rb26 heads and i was basically make quick referrence to some of the gear which is different about the rb26 heads to the normal heads service centers deal with. I was not trying to give exact clearance spec's of the top of my head, as there have been way to many beers sunk since i last spec'd my valve clearances (to guides). All i remember is they are uniquely large clearances on the exhaust side and it catches many people out. Where it's 2-3 thou or 4 thou isn't what this guy is interested in i believe but more the issues he need to deal with to built a strong health rb26.
pete
O i forget get some sump baffles or a new sump if it fits into your bugget.
look for oil control thread by sydkid and get most of that done aswell.
LOL RB26s cheap i wish! Dont think the tomei gaskit kit has everythink you need for a rebuild aswell?
Main thing to remember is anythink you dont do now could cost you another rebuild later.
a rebuild in the future after this current 1 i gotta do is something i really wanna avoid. the problem is i know stuff all about motors and rebuilds.
theres no way im gonna be doing it myself. im leaving it all to a mechanic. i still would like to know some things that i could get done now when the motor is out.
like extrude honing the exhaust manifold. port polish the head. ive read u guys talking about it. as i said above im :/
apart from resizing the valve openings, what else is involved in a port and polish??
what kind of things do i need to get done with the bottom end? i have been led to believe that the bottom end in rb26's are tough as and wont need any work.
sorry for the hijack
Great pistons.
Thankyou gentlemen. I might actually give the Wiseco's a shot, but if I can grab Marks number that would be great Paul. PM sent.
Can I suggest you not install forged pistons. I did in my RB25DET, and I cannot stop it devouring oil.
Forged pistons need to be HOT, and my experience is that normal driving does not seem to introduce enough heat to force the piston to expand properly.
What piston to bore clearances did you use? What pistons?
well fellas
heres a copy of a parts list from a pro engines build that was posted on the site a few moons ago
should be of some use to a few
theres abit to then aye,but i no when i do my biuld ill be doing it right the first time as i dont want to be up for more costs if it lets go..
i use the wiseco pistons 87mm with a 4 thou clearance, invest in some good rod prepping, and get new ARP bolts for the rods, as was said before the stock GTR bolts are well BS. get your cranck checked, and use new bearings allround, i reccomend the ACL black race series, top stuff. and i run the wiseco pistons on 450 AWKW and i drive my car pretty much every day. treat your engine correctly ie good warm up, on time service, let it cool down. and yea owning a RB 26 is like having a super high maintance GF, ie your wallet will be begging for its life :)
well fellas
looks to be well priced and what people should expect to be paying
Mate I just rebuilt my GTR about 6 months ago this is what I did
NISSAN N1 CRANK SHAFT
NISSAN N1 OIL PUMP
NISSAN N1 WATERPUMP
NISSAN GASKET KIT
NISSAN TIMING BELT
EXEDY TWIN PLATE CLUTCH
TOMIE OIL RESTRICTOR
ARIAS FORGED PISTONS
EAGLE RODS
ARP HEAD STUD KIT
COMETIC HEAD GASKET
RESLEAVED BLOCK AND DECK
KING MAIN BEARINGS
KIN BIGEND BEARINGS
PERFORMANCE VALVE SPRINGS
HEAD SERVICED PORT & POLISH AND K LINNERS
SUMP BAFFLES
INJECTOR FLOW TESTING
DRIVE BELTS
NISSAN COOLANT
OIL & FILTERS
HKS 2530 TWIN TURBOS
HKS DUMP PIPES
HKS SUPERDRAGGER SYSTEM
HKS CAMS
OIL COOLER
HIGHFLOW CAT
850CC DENSO INJECTORS
BOSCH FUEL PUMPS
TRUST TWIN PODS
ROM ECU
STRUTE BRACE
REAR SWAY BAR
ENGINE DAMPNER
AFTERMARKET SUSPENSION coils
d jetro
eboost 2
+ OTHER STUFF I'VE FORGOT
BUILT BY TIM @ SIKEMWREX RACING
This setup for 550rwhp daily
Forged pistons do expand but if an engine is built with the right clearances it shouldn't really burn any oil.
I would suggest as Abobob alluded to that the engine wasn't built tight enough.
On the upside- when an engine is built loose it will typically make more power even though it consumes oil. Race engines typically have 6-8 thou bore to piston clearance and chew through the oil but there is less friction and therefore less heat generated which improves the reliability and life of he engine.
  • 1 month later...
Should this be of concern for me? My motor does take a long time to heat up, and you've really got to flog it if you want it to be hot. I don't mind warming my car up for five minutes (I do it anyway) but would that be long enough with forgies.
Do all brands of forged pistons take an equal time to heat up and set into position?
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
