Hi Guys im in need of some help here...
My stagea has developed a shudder through the steering wheel under heavy load when launching o. It doesnt always happen, and only happens in first or 2nd gear (standard auto still).
I have noticed its more likely to happen when i have the wheel turned, say powering out of a round-a-bout.
The shudder will continue through first and second gear, if i back off and then accellerate again it dissapears.
You can really feel it through the steering wheel, it gets a really strong vibration or shudder.
I thought it might have something to do with the front drive shaft or something, but not having a clue about the attessa system or 4wd for that matter, I dont know where to start.
Has anyone else had this problem or any ideas on whats causing it?
Cheers,
Ben.
https://www.sau.com.au/forums/topic/147404-heavy-vibrations-help-me-please/
Yep, I would look att the CV joints in the front drive shafts too, If it was the front drive shaft, like mine was, it wouldn't go away after backing off, or in any higher gear.
read somewhere in another post that when the solders on the AFM becomes dry and cracks...when travelling on uneven roads the connections can move about slightly causing the car to jerk or shudder...then when on a flat road the revs become stable again...might be a faulty AFM which from what i hear is very common...doubt its the cv joint because when this wears out...the shudder or noise is quite consistent and doesnt go away. Dont know how a broken atessa feels ..maybe someone who's had this experience can share more.
my car has developed this cough when idling...happens especially when hot but the car revs smoothly when driving....really buggin the shit outta me...changed and gapped plugs to 0.813mm ..so definately not that
trying to go through the process of elimination too..so next week im gonna hafta clean the AAC and solder my AFM
anyone who's had this before would really appreciate some help.
yeah its defenantly not afm.
Its in the drive for sure, just not sure where yet! im gonna sneak it into the workshop and try have a good look underneath with the hoist and see if anything is visable.
I hate it when my car isnt 110%!!!!
Come to think of it...my car used to do that ...always in 1st or 2nd and when under load..eg uphill ascent...always thought it was uneven road...but apparently was caused by a faulty coil ...hardly noticeable but gradually reared its ugly head...solved now with some high temp silicone.
even if ur coils arnt shot...might be worth doing ...look in the DIY threads.
  • 8 months later...
Hi peeps - I know this is an old thread and has been covered a few times but I'm concerned as my Stagea has developed exactly this vibration issue. I'm in the UK and the cars are a rarity over here so I'm trying to research this as much as possible before taking it in next week to get sorted. I've had the wheels balanced but it has not improved. I had the wheel alignment checked at the same time and they said that they set all 4 wheels parallel as per most other 4WD vehicles - but I have noticed some feathering on the front tyres since then. Was it wrong to get them aligned like that? It is in next week having a load of work done so I want them to try and sort this too. All 4 tyres are toyo proxes but the fronts are slightly less worn than the rears, could this be an issue? I've got a set of Tein SuperWagon Coilovers going on so they can have a good look around then - and I guess the suspension swap might even remove the problem anyway. Any suggestions would be really appreciated - I'll try to glean as much as I can from the other threads - but I'm not really technically minded so any 'plain english' (or plain ozzie) explainations would be great. Cheers peeps. :rofl:
Ps - I'm also having a Blitz down pipe, a GReedy Front mount fitted and the Turbo is being re-built with GT30 internals - looking forward to getting it back after!
John
I had the exact same problem all the time, for about 4 months. My front tyres were worn. I replaced them with new ones, and have not had a repeat in six months. I consider the issue fixed
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
