Hi Guys im in need of some help here...
My stagea has developed a shudder through the steering wheel under heavy load when launching o. It doesnt always happen, and only happens in first or 2nd gear (standard auto still).
I have noticed its more likely to happen when i have the wheel turned, say powering out of a round-a-bout.
The shudder will continue through first and second gear, if i back off and then accellerate again it dissapears.
You can really feel it through the steering wheel, it gets a really strong vibration or shudder.
I thought it might have something to do with the front drive shaft or something, but not having a clue about the attessa system or 4wd for that matter, I dont know where to start.
Has anyone else had this problem or any ideas on whats causing it?
Cheers,
Ben.
https://www.sau.com.au/forums/topic/147404-heavy-vibrations-help-me-please/
Yep, I would look att the CV joints in the front drive shafts too, If it was the front drive shaft, like mine was, it wouldn't go away after backing off, or in any higher gear.
read somewhere in another post that when the solders on the AFM becomes dry and cracks...when travelling on uneven roads the connections can move about slightly causing the car to jerk or shudder...then when on a flat road the revs become stable again...might be a faulty AFM which from what i hear is very common...doubt its the cv joint because when this wears out...the shudder or noise is quite consistent and doesnt go away. Dont know how a broken atessa feels ..maybe someone who's had this experience can share more.
my car has developed this cough when idling...happens especially when hot but the car revs smoothly when driving....really buggin the shit outta me...changed and gapped plugs to 0.813mm ..so definately not that
trying to go through the process of elimination too..so next week im gonna hafta clean the AAC and solder my AFM
anyone who's had this before would really appreciate some help.
yeah its defenantly not afm.
Its in the drive for sure, just not sure where yet! im gonna sneak it into the workshop and try have a good look underneath with the hoist and see if anything is visable.
I hate it when my car isnt 110%!!!!
Come to think of it...my car used to do that ...always in 1st or 2nd and when under load..eg uphill ascent...always thought it was uneven road...but apparently was caused by a faulty coil ...hardly noticeable but gradually reared its ugly head...solved now with some high temp silicone.
even if ur coils arnt shot...might be worth doing ...look in the DIY threads.
  • 8 months later...
Hi peeps - I know this is an old thread and has been covered a few times but I'm concerned as my Stagea has developed exactly this vibration issue. I'm in the UK and the cars are a rarity over here so I'm trying to research this as much as possible before taking it in next week to get sorted. I've had the wheels balanced but it has not improved. I had the wheel alignment checked at the same time and they said that they set all 4 wheels parallel as per most other 4WD vehicles - but I have noticed some feathering on the front tyres since then. Was it wrong to get them aligned like that? It is in next week having a load of work done so I want them to try and sort this too. All 4 tyres are toyo proxes but the fronts are slightly less worn than the rears, could this be an issue? I've got a set of Tein SuperWagon Coilovers going on so they can have a good look around then - and I guess the suspension swap might even remove the problem anyway. Any suggestions would be really appreciated - I'll try to glean as much as I can from the other threads - but I'm not really technically minded so any 'plain english' (or plain ozzie) explainations would be great. Cheers peeps. :rofl:
Ps - I'm also having a Blitz down pipe, a GReedy Front mount fitted and the Turbo is being re-built with GT30 internals - looking forward to getting it back after!
John
I had the exact same problem all the time, for about 4 months. My front tyres were worn. I replaced them with new ones, and have not had a repeat in six months. I consider the issue fixed
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
