Hi Guys
I have an R33 GTST and it is haven some major problems lately.I Installed the Apexi Power FC Last night and I want to take it to get dynoed and tuned but the car is running like shit. It will hunt around every now and then, It surges really bad, it feels like the engine dies and when you accelerate only the turbo opens up and the engine makes a dull machine gun sound and jerks really bad. The RPMS also drop while you accelerate and then the engine kicks back in or sometimes it will drop way down until it stalls itself. For some reason it happens on and off and I'm starting to get worried as the episodes last a minute or two and at the moment it's to hard to drive and it will happen on straights or corners just out of the blue. I was thinking it needs a new fuel pump or it's not getting enough fuel. The car will also only half accelerate, you accelerate but it's like it will hold back.I have also tried resetting the ECU and doing the Idle test. I'm running out of ideas and these episodes started last week before the ECU was put in. What is is? Please help I want my baby to run again
3" cat-back kakikomoto exhaust
Splitfire Di Ignition Coils
Hybrid Intercooler
HKS Pod Filter
Blitz Boost Gauge and Full Turbo timer
Apexi Power FC + HC
https://www.sau.com.au/forums/topic/147420-serious-help-needed/
sounds like dieing fuel pump to me.
What pump should I use. Is the Bosch 044 any good? I've read alot of highly modified cars use them. Also how amny is to many or not enough? I've seen some with 2 or 3. Any ideas would be greatly appreciated.
With your current modifications
stick to a 040 in-tank it will support 500hp and costs about $190.
An 044 is external and will cost more to connect.
PS. Before you fire up the engine can you hear
the pump priming?
the pump priming?
Yeah you can for a second or two sometimes
Edited by Shoudi
my reasoning is...
car works fine
something is changed
car runs like shit
...therefore, the reason the car runs like shit is directly related to what you changed
have you tried putting the stock ECU back in to see how it runs?
my bet is the powerFC not connected properly..
good luck
Warren.
I had an intermittant problem similar a while ago. Car would stall (almost), then run fine, then be shit again for no reason. Changed everything from AFM's to pump to CAS to wiring etc. Turned out to be the connection on the top of the PFC. Because of the centre bolt, the outer pins would lose contact as the plug rocked back and forward. Put large zip ties around the ends of the PFC and plug. See if it helps.
It was acting like this exactly 4 days before installing the PFC. I wnet through the half hour idle set up and only a little bit of black smoke comes out but when it plays up a shit load does. It had same problems a week ago with the stock ECU.
so I assume it's prob not the pfc entirely, although the symptoms may have changed a little due to the pfc settings. it sounds like an AFM to me but I don't know what the machine gun sounds are from. if it was making them only after the pfc it might be the ignition settings. either way just go back to the stock ecu and start diagnosis from there at least you have a known start point. use the self diagnostics to see if it's a sensor fault.
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
