The problem with my Afm required it to be internally repaired (the solder joints on the inside of the plug to the afm's circuit board Under that square black cover) a clean wont do unfortunately.
It would be better for you to swap it with a known good working unit to test.
https://www.sau.com.au/forums/topic/14743-stuttering-probs/#findComment-300305
i spoke to dr-drift aka sam and hes on to something, he said that maybe theres a problem with the solinoids that are on the hicas steering,now that would explain why it only does it to the left, maybe theres a short or it robbing power away from the fuel pump??? sound logical
https://www.sau.com.au/forums/topic/14743-stuttering-probs/#findComment-300314
well i unpluged the computer under the parcelself and it still did it,and i think the hicas system is hydraulic. Sooo where do i go from here??? now i know it doesent do it in reverse on when u go forward,and it even does it when you going walking pace to the left, soooo maybe its some sensors somewhere, is there any sensors in the steering rack????? also when u hear backfiring noise that mean rich fuel mixtures cause thats what its doing after the steering wheel goes back to straight, which make me think that maybe its not playing with fuel pump but maybe spark??? does that sound right???
https://www.sau.com.au/forums/topic/14743-stuttering-probs/#findComment-301226
Sounds like something to do with the fuel pump..or even something silly like fuel line being twisted or pinched or something as you turn. Check your fuel filter as well, can't hurt to replace.
Backfiring is overly rich yes.. i get it with low-grade fuel sometimes as well.
https://www.sau.com.au/forums/topic/14743-stuttering-probs/#findComment-301267
The skyline fuel filters are replace type only Z200 I think.
You in your profile state your car is an r31 coupe is this the Rb20 equiped model? if so on the drivers side of the engine bay is all the soildnoids and hydrolic sensors May be you could un plug them an see if the car still plays up also thats the same side as the fuel lines check as someone else stated that the fuel line is not fouling with the steering rack(getteing pinched) . Still dont rule out the Afm until you have swapped it with a known working unit.
https://www.sau.com.au/forums/topic/14743-stuttering-probs/#findComment-301784
well i changed the sparkplugs and its kinda better now,but i found that the 2 plugs that go into the igniter box thing at the back of the engine,when i fiddle around with them then it stops, i tried to do some fixing to the plugs but its a no go,so which makes me now think its the igniter pack thing, does this thing stuff up much???
https://www.sau.com.au/forums/topic/14743-stuttering-probs/#findComment-304315
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
