Hi, i received some for free off the seller on ebay. Im yet to fit them properly to my car, and paint them, but here's a rough look at what they're like on a r32.
I must admit, they are not the best quality fiberglassing iv seen, but in many ways, you get what u paid for.
yeah a mate and i bought a pair each off this guy, said they were for a s1, but they turned out to be clearly for a s2...
like teh dude above, not the best quality.
ours needed to be sanded back and prepped and maybe a little more fibreglass before you could even consider painting and fitting.
both eyelids weren't identical either (i.e. weren't bent in the same way - but obviously mirrored)
My eyelids came today in the mail, not the best quality fibreglass but they sit correct, cut properly and no need for any more re-fibreglassing.. paint and fit, no re-shaping
At the end of the day, im happy with them due to the fact that i dont have to alter them in any way
Thats a first.....
  • 1 month later...
hey i purchased eyelids for my 32 of ebay i fianally got them but wasnt happy wit the quality of the fibreglass they didnt end up fitting the headlight properly and didnt want to sit on the side indicator wasnt moulded prop
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
