I have just received my turbotech boost controller and wondering how to fit it.
I know it goes between the wategate actuator and turbo but what does it look like and where is it?
Anyone have any pics of install?
I have a R33 gtst series 2.
Also when i fit it will the two stage boost solinoid still function or do i have to bypass it somehow?
CHEERS
dave
you have to bypass it run it. there should be a hose from you intercooler intake pipe to the solinoid run that to the boost controller and then run the boost controller back to the actuator..
do you have a boost gauge?
you'll want one..
lol then it goes between the cooler pipe and the wastegate actuator, make sure its wound all the way down (check your manual), the stock boost controoler has 3 lines just take them off i think from memory one needs to be blocked up just use a screw or something. Then make sure you have a good boost gauge not the shit factory one and go for a drive it should be like 5psi etc then increase the boost little by little untill you get your required boost.... i hope i have helped
OK done.Now running a constant 9psi.Would this be a safe boost level for stock intercooler.I have a tube and fin kit waiting in the garage to be fitted.Then ill go 11psi.But then i get into the rich and retard bracket dont i.What are you running on your setup?
post-26632-1166237407.jpgthis is what you did right? its not very difficult, only two hoses.
you can take the stock solenoid out or leave it in the car, either way block all unused hoses by screwing a suitable screw into the end and maybe a zip tie over it. there is only one small hose you need to do this to though. if your having trouble maybe you forgot this bit lol.
do u screw the bolt in for less boost or out? im still learnin haha
screw in for more boost, so when you first put it on have it screwed out so you dont overboost straight away, turn it bit by bit til you get to a good boost level.
PLEASE NOTE : this instruction is for turbotech design only, some other bleed valves may work differently.. if you have a different controller it may be the opposite. If so and you blow up your turbo dont come crying to me.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
