OK guys i got this DR30 i gotta get rid of...
specs are as follows.....HKS TO4 turbine kit,external wastegate,Fcon injector computer,greddy boost guage,greddy exhaust temp guage,HKS EBC,greddy bov,adjustable shocks,small intercooler,hks turbo timer.This car is very fast!I was quite shocked how fast!The exhuast note is great!I want 220,000 yen for the car FOB if i cant sell it were gunna use it as a track pig!Have spoken to prank about advertising this car in this section...he said its ok,so please dont delete.thanks. [email protected]
https://www.sau.com.au/forums/topic/14750-dr30/
Originally posted by MrMayhem
that would be cool
looks like a blitz k27 not a to4....  pedantic i know
?????i dont need a run down on a car that you havent even seen....why does everybody do this when people sell stuff????do i need to tape peoples mouths shut???:D
https://www.sau.com.au/forums/topic/14750-dr30/#findComment-299311
    • I hope so.  It seems pretty nice. OEM feel the lot.
    • I wouldn't be surprised if this helps. And I wouldn't be surprised if it keeps changing for a bit after the new slave&hose go on, because I find that my clutch always does this sort of shenanigans after any serious dismantlery. And then it settles down after a few corrective tweaks such as you've already done.
    • Ist post I joined after seeing this thread  I have just installed on a r33gtst at first I liked it but I am finding the peddle free play changes …. To a point I have had a zero free play condition and the thrust bearing stayed engaged. I had to back off the adjustment on peddle.   I am about to change slave and fit a braided line to see if I can get a better result
    • I sent off a message to a guy, waiting for his response if he can do it or knows someone.
    • Just remake the bracket. It's just bent steel with a nut welded to it. It is thinner material than you might remake it in. You just have to get the thickness right in places where it absolutely must be (and there might not actually be any such places. The same motor trimmer who you get to work on the outside of the seat would no doubt have done exactly this type of repair in the past.
