Just noticed,
My rb25det oil pressure dropped, from the *4 Mark, down to the first line,
normally always sitted at the 4 mark, now its sitting at the first line *unmarked line*,
No oil leaks, I could find, some slight oil residue comming from rocker covers.
Oil level is fine, But have noticed turbo making slight werring or whining noice when boosting hard now.
Thinking that My oil pump could be showing its age..
anyone agreee? disagree?.
https://www.sau.com.au/forums/topic/147504-oil-pressure/
firstly i'd get that seepage out of the rocker covers fixed.
and its more than likely to be your turbo rather than your oil pump. a blown oil seal in your turbo will cause the lower oil pressure.
check for oil in your intercooler piping at the lowest point then report back.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753081
Pulled off front pipe (lowest pipe) , found small trace of oil residue, when i whipe my finger on bottom of the inside of the pipe,
I would assume this is normal?
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753362
same pressure cruising or at idle. or not much change noticable.
oi is nulon high tech fast flowing 10-40w, for import turbos etc.
been using same oil since i got it.
havnt checked with full throttle yet.
Edited by silverbulletR33
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753926
im asking for the actual pressures.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753937
OK cruising at 110, and giving it a bit, went just over the *4 mark.
thought it Might possibiliy have something to do with the viscosity of the oil, so i did a oil and filter change, and now back to normal.
now sitting on 4-6
So, Nulon Hi-Tech, fast flowing stuff, which is 10-40w, after 3900kms looses some viscosity which make the drop in oil pressure.
:) maybe ill try new oil next time.
theres gotta be something wrong for it to loose its viscosity only after that muc kms? or is this the norm?
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772147
Sounds like the oil sender/guage is faulty.
Best bet would be to use a second guage to confirm that to make sure that it's not a major issue.
I don't think it's the oil pump, because if the oil pump was going, the oil pressure would be low, not high.
on idle, it should be around 2. If it's up at 4, that's reading twice as much, so i'd think it's the guage/sender
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772779
I don't think there's anything wrong with the oil. For the pressure to double, that would have to be pretty majorly wrong.
That nulon oil is good stuff.
It could be anything mate. tempamental sensor? Or guage a bit lazy for a moment.
Just see if it happens again with this lot of oil.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772782
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
