Just noticed,
My rb25det oil pressure dropped, from the *4 Mark, down to the first line,
normally always sitted at the 4 mark, now its sitting at the first line *unmarked line*,
No oil leaks, I could find, some slight oil residue comming from rocker covers.
Oil level is fine, But have noticed turbo making slight werring or whining noice when boosting hard now.
Thinking that My oil pump could be showing its age..
anyone agreee? disagree?.
https://www.sau.com.au/forums/topic/147504-oil-pressure/
firstly i'd get that seepage out of the rocker covers fixed.
and its more than likely to be your turbo rather than your oil pump. a blown oil seal in your turbo will cause the lower oil pressure.
check for oil in your intercooler piping at the lowest point then report back.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753081
Pulled off front pipe (lowest pipe) , found small trace of oil residue, when i whipe my finger on bottom of the inside of the pipe,
I would assume this is normal?
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753362
same pressure cruising or at idle. or not much change noticable.
oi is nulon high tech fast flowing 10-40w, for import turbos etc.
been using same oil since i got it.
havnt checked with full throttle yet.
Edited by silverbulletR33
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753926
im asking for the actual pressures.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2753937
OK cruising at 110, and giving it a bit, went just over the *4 mark.
thought it Might possibiliy have something to do with the viscosity of the oil, so i did a oil and filter change, and now back to normal.
now sitting on 4-6
So, Nulon Hi-Tech, fast flowing stuff, which is 10-40w, after 3900kms looses some viscosity which make the drop in oil pressure.
:) maybe ill try new oil next time.
theres gotta be something wrong for it to loose its viscosity only after that muc kms? or is this the norm?
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772147
Sounds like the oil sender/guage is faulty.
Best bet would be to use a second guage to confirm that to make sure that it's not a major issue.
I don't think it's the oil pump, because if the oil pump was going, the oil pressure would be low, not high.
on idle, it should be around 2. If it's up at 4, that's reading twice as much, so i'd think it's the guage/sender
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772779
I don't think there's anything wrong with the oil. For the pressure to double, that would have to be pretty majorly wrong.
That nulon oil is good stuff.
It could be anything mate. tempamental sensor? Or guage a bit lazy for a moment.
Just see if it happens again with this lot of oil.
https://www.sau.com.au/forums/topic/147504-oil-pressure/#findComment-2772782
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
    • I've ordered a new fuel pump and plan to do all the fuel tank hoses at the same time. Those are the hoses I would rather not go on the road.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
