why? arent you wearing a bra steph :)
Because i have a dirty mind ok?! geesh! :)
Nice to meet you all today guys...
Sorry Sam i could not get dirty... I felt too pretty to get dirty... :D
Funny thing tho as soon as i got to the exhaust shop @ redcliffe I got a huge dob of oil on my shirt... ;)
So how high did the car end up being??? Suitable???
hehehehehehehe.....theres some proof....vagina! hehe!
ok sorry ill shut up now
BY THE WAY, although bra's are extremly annoying at times ill have you know im fully dressed you sicko......
jokes!
the sicko bit i was joking about....by the way...just that
  • Replies 93
Still getting used to it, The breaks are much better now, they dont squeak, squeel or make any noise at all. I have noticed a tendancy for the car to understeer a bit more with the suspension in there, however I corrected this by increased front tourque. Other then that, it seems to corner alot better and the suspension is not so stiff that its unbearable, its actually quite a nice ride. I will know for sure when i have a chance to go up mt nebo with it.
I just dont know if I like the look of it so low. It will take some getting used to...
Also I need lower profile tyres I think.
And then ringing me for help. lol...
Hey shane.
I would just like to say 20/20 cricket rocks. NSW suck (even tho they did need 5 6s in the last over and got 3 of them) and QLD rock as we won! WOO!
But almost 28000 people at the gabba tonite for a domestic 20/20 game, was awesome.
ur fault for saying if i've got any questions dont hesitate to call u, so u kinda dig ur own grave :laugh:
can i get you take me for a lil burl in her ian? i wouldnt mind seeing how the new shocks are :)
is your suspension adjustable ian? if you want i can help you tune it to suit the car, if you havent already done so.
let me know, its not too hard to do, just trial and error basically :laugh:
ur fault for saying if i've got any questions dont hesitate to call u, so u kinda dig ur own grave :P
It's all good mate, you know I'm only taking the piss. You CAN call me anytime....I'm only here to help.
I'll still put on a dress for you if that's what you want.
Yeah mike, its fully adjustable however im happy with the settings it has on there atm... They werent brand new, came off another car which had blown its engine (they werent on for long) and the previous owner set them up well it would appear.
I just took the car up nebo then, the difference is remarkable... Much more stable ride, much less body roll and alot more traction, espically when you dial the front tourque up.
thanks sweetheart, but this time can u make sure u wash it :P
I know this isnt about bra's or no bra's, or your suspension. But my rear coilovers squeak a bit a stressful loading. i do not know why.
Just thought i'd ask, since were still on topic.........
heh.
They are apexi n1 street.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
