SOLD
Nissan R32 Godzilla GTR V Spec II
White, fully re-built engine, highly modified car, thousands spent have all receipts, serious buyers only. Personalised plates, rego, perfect condition, very regretful sale.
$30, 000 Serious buyers only
ph: 0438 881 462 or PM me
I live in Brisbane
As to the list of mods, here are most of them:
Trust front mount
Twin 3 inch exhaust
HPC coated dump pipes
HKS 2530 turbos
Toyo T1R 235/40/17 brand new
G7 Panasport Rims
272 HKS cams
HKS cam gears
Ogura twin plate clutch
Sard 720 cc injectors
In tank fuel pump
Air water bypass/bleeder
Remote oil cooler and filter and speed flow fittings
Custom blow buy, speed flow fittings
Forged pistons
Brand new crank (R33)
N1 Balancer
N1 Water Pump and Oil Pump
O-ring block
reconditioned tail shaft
ARE radiator
Silicon radiator hoses (Blue)
Gates timing belt
Link ECU
Brand new head, valves etc
Alarm, auto windows up
AVCR
Autometer fuel pressure and boost gauges, on the piller
NGK iridium spark plugs
Runs Motul 800v oil
no air flow meters, runs a map sensor
Koni adjustable suspension
White leather inserts
Isotta steering wheel
Isotta windsceen wipers
Tinted windows
Big stereo, cadence Z4000 amp to run the splits, VDO HPC 1700 6.5inch splits
6 x 9s in the back
US audio bone crusher 1200w Amp to run the subs 2x 12inch
Battery in the boot
post-18869-1166173365.jpgpost-18869-1166173548.jpgpost-18869-1166173853.jpgpost-18869-1166173976.jpgpost-18869-1166174089.jpgpost-7721-1129008347.jpgpost-18869-1166174333.jpg
Edited by MYR32GTR
https://www.sau.com.au/forums/topic/147526-sold/
  • 2 months later...
Could you please list the VIN to enable confirmation that it is a genuine V-Spec II.
It doesn't have the V-Spec II label, rims, rear spoiler or front lip but you could have removed all of these items. It does look like it has the Brembo brakes though.
https://www.sau.com.au/forums/topic/147526-sold/#findComment-2969464
  • 3 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
