Hey everybody,
Putting my R33 up for sale - reason is I'm getting a car through work in the new year!
Details for the car
1993 - R33 GTS-T Automatic (With shift kit)
*Stage 2 Shift Kit installed and running well
*Walbro fuel pump
*Frontmount Intercooler
*Boost Controller (Running 10PSI at the moment)
*Apexi Boost Gauge
*Apexi Pod Filter (with heatshielding)
*Full Exhaust System
*Turbo Timer
*Full alarm system with remote boot release
*18"x8" Rims with 235 Rubber on the front and 265 Rubber on the rear (heaps of tread left)
*Near New brake pads (Bendix Ultimates)
*GTR Coilpacks (replaced the old ones which had the missfiring issue, no issues with the new coils)
Car has been a real pleasure to drive over the last year and a bit - very good just to cruise around in, but has the power if you need it.
The car has approx 1357XX KM's on it at the moment - it has always been serviced at at regular intervals with Motul oil and other quality parts - the fuel filter was also replaced last service.
Its very clean inside and out and I've looked after it - it has been my daily driver and its undercover when I'm at work and at home.
Here are some pictures as well.
Sorry about the rain - best shots I could get today out in the sun (what was left of it!)
I'm after $12,000 (PRICE REDUCED!) ONO on the car - Can supply saftey cert easily.
Please PM me, post here, or call/sms me on 0438 647264 if you have any questions, or would like to come check the car out.
Cheers
Phil
Edited by Space Ninja
https://www.sau.com.au/forums/topic/147539-bne-r33-gts-t-skyline-price-reduced/
Hey everybody,
Details for the car
*Walbro fuel pump
*Apexi Boost Gauge
*Turbo Timer
I'm after $14,000 ONO on the car - it has a Saftey Certificate right now and it is valid for the next 7 weeks, so the car is ready for sale immediately.
Cheers
Phil
hey man nice r33 you've got there
what wheels are they on it?
Hey mate,
The wheels are all 18"x8" Avanti Rims I bought locally in Brisbane - front tyres are 235's and the rears are 265's - all are Toyo Trampio's (all matching etc!)
Thanks for the comments !
  • 3 weeks later...
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
