non-turbo, 177,000 klms, auto and it looks like it might need some attention - id suggest rwc and inspection done by a performance workshop
edit - whether or not that 177,000 klms is tru or not is another matter....and tis an r32
Edited by emsta2003
177 000 isn't really that bad
how long do you reckon the engine would have in it?
basicly the body looks ok to me so the only thing in question is the engine?
is this a import?
Josh
Edited by -BORED-
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
