Green Light! This Cruise WILL go ahead.
I just checked the rader again and there won't be a problem for us cruising down the gold coast. So, post up if you want to meet!
I'll be heading out tonight, and thought I'd organise what we did last weekend where we had a pretty good turnout of Skylines, aloing with some other cars.
We'll meet at Springwood Crazy Clarks (Carpark Facing the freeway) and head down to Broadwater Car Park. What we do after that is up to you guys, we can have a chat and see what you want to do. Last time we went up to Tweed Heads so maybe the same thing, or something diffrent.
Should be a good night out, hope to see you all there!
Meeting Place: Springwood Crazy Clarks Car Park (Facing the Freeway)
Meeting Time: 8pm
Departure Time: 8:40pm
So who's in? I'll see you there! Any questions, running late etc give me a call on 0433 63 95 97 :(
Edited by R33MidnightRacer
https://www.sau.com.au/forums/topic/147582-saturday-night-cruise/
Looking on the rader looks like we will get some rain this afternoon, however at the moment, looks like it will be a clear night from around 7ish till late, so don't let the rain we get this afternoon scare you away!
Doesn't look like many people are going, I don't think I'll be heading down. Maybe save this for a Sunday or next weekend.
Sorry guys - If other people want to meet up there, cool as ..but doubt I'll be there :(
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
