Turn your sarcasm detector on lol
But yeah, the GTR's record will never be beaten because, as Paul said, the track has changed. It'll always retain the record for the old track configuration, simply because there's no way for anyone else to compete for it now. The fact that there were no safety cars (I'll take your word for it Karen :P ) would certainly have an impact too, but regardless it all academic.
I do miss the days of different types of cars, the "supercars" are sooo damn boring. It used to be good seeing cars that had their own strengths and weaknesses but were still competitive overall. V8 Supertaxis are incredibly bland in comparison. Unfortunately it looks like there's a bucketload of money in it, so it's here to stay ;) I'd absolutely LOVE to see some variety in the series. It'd also be nice if, instead of the local manufacturers crying because they were being flogged, they used it as an incentive to step up to the plate. As it stands, there's not a great deal of a reason for them to do so, because they're not being compared to vastly superior machinery.
Meh anyway, it's all wishful thinking. Not going to happen, guess I'll just go back to the bike racing and rallies :huh:
But the only way to 'step' up was to go smaller capacity turbo. Which isnt really what the general buying aussie public would want. Remember there were also some pretty hefty resrictions against the V8s to start with. And the GTR was an internationally used car, the Aussie cars werent. That makes a lot of difference in R&D dollars and testing time.
Nah they could have also stepped up by making what they were allowed to use, work better for them, just like the manufacturers they were chasing. That's how the small-cube turbo crowd got so far in front - they kept making innovations, while the local V8 crowd stuck with 16-valve iron V8s, putting them in heavy cars with comparitively primitive suspension and then complaining when they couldn't keep up.
Point taken re the Falcon/Commodore not being an international car, but surely they could have used some of the high-tech bits from their parent companies' overseas models.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
