hey guys
88 nissan a31 cefiro factory 5spd manual with r32 rb20det engine - non hicas and non abs but with VLSD
car has 12X,XXXkms on cluster and 7X,XXX on engine
car has not been in an accident as far as im aware or the previous owner states (no visible signs anyway)
mods:
gtr r32 fuel pump
Straight through turbo back exhaust 3"
Impul ECU
Kei Office coilovers
Eastbear cooler piping
HKS mushroom pod and mild steel inlet pipe
GTR r33 front mount cooler
stripped interior (backseats and seatbelts supplied and carpet is still in car - just boot linings and sound deadener removed)
16" 5 spoke rims
now the catch... its uncomplied but comes with import approval
things which require fixing:
windscreen has a crack along the bottom
chassis rails need capping (damage during transport)
new rear brake line required on the drivers side rear
car requires 2 front seats
dash has 4 holes on passenger side for gauges - dependant wether its used as a track car or a street car these may require to be filled
no stereo surround
and some minor work to get it running (some things are disconnected etc... a days work could see her running)
located in sa... car is navy blue... paintwork is average - could do with some touchups...
selling due to house hunting - can't keep 2 cars and its taking up space
this does need to go asap - i know some work is required however its only fiddly things... and wouldnt take too much more work to be registered
no pics atm... as dont have any of what it looks like atm (virtually a stock navy blue cef with rims lowered front mount and exhaust)
would like to see this go asap as mentioned above... some tlc and she'll be good!
Exhaust Technology
Jack Baker TyrePower
Doyle Crash
Making drifting possible for SA!
https://www.sau.com.au/forums/topic/147609-fs-nissan-a31-cefiro-suit-project/
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
