i,ve been reading this thread very closely, and have just about done everything here. bought a high flowed turbo(same as the pics last page) had no problems with boost on my stock turbo, set at 12 and dropped to 10 as all bleed valves do. thought id chuck on the high flow and set it to 12 to 13 psi as i still had stock injectors. went for a tune and went to 12, leveled and slowly climbed to 17 at the end of the rev range. since then i have remover the turbo and machine out the waste gate hole from 24 to 28 mm giving me a 36% increase in surface area, didn't work. had a 2 1/2 " split pulse dump pipe that i modded to a bell mouth, didn't work. got rid of the dump pipe and put a 3" bell mouth front/dump pipe on, didn't work. swapped actuators, didn't work. removed the bleed valve completely and put it directly onto the standard tapping point, didnt work. i am now about to go the other way and put a 2" restriction plate in my exhaust to see if that rectifies the problem. the car has been detuned to 230hp at the moment so i dont pop anything.
i am running a safc2, full 3" exhaust (only restriction is the cat).
  • Replies 68
Posted Images
I now can say that i solved my boost issues once and for good. I was beginning to doubt my actuator too. I bit the bullet and bought a brand new Gizzmo MS-IBC and what a diff. Super easy to install and tune. Tuning took me just around 10 mins. Just have to fine tune it now but i did that on the motoway to work this morning :ermm:
Boost comes on super quick compared to the stock actuator. Rock steady 7psi to the redline. Sorry but i have to suggest an ebc. Just out of curiosity, have you tried one at all?
Trust me, i thought i had a "too free flowing" exhaust as well but its not.
ok, just fitted a 2" restriction plate between front pipe and cat. took the car for a blast and sat rock solid on 7 psi (have taken bleed valve out and gone from standard tapping point to waste gate). waiting for car to cool down and will fit a 2 1/4" and see what that does. will keep updated!
ok, 2 1/4 with no bleed gave me 10 psi. re fitted bleed valve(set at 12 psi) and went to 12.5 @ 7000 in 2nd. my problem looks like too much flow through exhaust. booking in to get full tune next week and hopefully around the 300 rwhp figure?
Good one mate! Im happy you got that sorted out!! :)
I got the ebc for $240 from modyoucar.com.au when they had the special. Over here in nz, it retails for around 5-600! so i got it for half price inc delivery.
Just out of curiousity, hows your torque curve? Whats your peak torque and at what rpm?
When i had mine stock, with just a catback and a pod, it made 330-340 Peak and over 300Nm from 2200 onwards.
  • 3 months later...
And i still say its rubbish :(
Not one person i know has had a problem here in Vic, and R33's are a dime a dozen
actually we have seen this problem on the dyno a few times , had a rb25det with front mount and good flowing exhaust suffer from this problem , even removed the actuator and opened the flapper valve all the way and loaded the car up on the dyno still made 13 psi of boost and tapered off to 12 at 6000 rpm , explain how and different actuator will help when the gate opening(hole) is physically not big enough to get rid of gases (also this vehicle made 200 rwkw on 12psi with stock turbo)
regards,steve
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
