your safe Jason
i have a JUST SLIDE IT IN sticker plastered across the top of my windscreen and havent been hassled yet
Help i need some sympathy I'm having such a bad week.
Firstly my wife gives birth to twins
Now tonight I missed out on division 1 in lotto by 1 number!!!
Got 5 numbers and 2 supplementarys. Oh well $25,000 aint bad either :P
Dudddeee, it could have been worse. She could of had triplets and there could of been one of each ;):D:):D Congrats on the twins mate!
